2 Project panels
Mike Damian
2 Project panels
on Sep 5, 2012 at 10:48:51 pm
Is there a way to bring up 2 project panels in After Effects? Not as simple as double clicking a folder like premiere. I looked under the twirly menu and under Window in the menus. Any ideas????
Brian Charles
Re: 2 Project panels
on Sep 5, 2012 at 11:25:29 pm
See this: http://aeportal.blogspot.ca/2011/04/etlat-edit-this-look-at-that.html
What you need to do is lock the the Comp viewer and choose New Comp Viewer from the Composition menu.
Mike Damian
on Sep 6, 2012 at 12:02:16 am
are we talking about the same project panel? I'm talking about where all my assets and folders show up. This tutorial seemed to be on composition and footage window.
Brian Charles
on Sep 6, 2012 at 2:39:53 pm
My apologies, I misunderstood your question.
I don't know of any way to have more than 1 project panel open.
Jon Bagge
on Sep 6, 2012 at 4:31:51 pm
You can only have one project open at a time. But you can import a project into another project. This will create a folder in your project containing the second project.
You can then copy stuff over, or do whatever.
Doing this won't change the imported project. The contents of the imported project will simply be added to your project.
http://www.jonbagge.net
Jon Bagge - Editor - London, UK
Avid - FCP - After Effects
Cassius Marques
on Sep 6, 2012 at 4:40:48 pm
If I may ask, why would you want to do this?
Mike Damian
on Sep 6, 2012 at 6:55:03 pm
I have a project with 70 comps. pre comps and a few hundred images. It would be beneficial to be able to open a separate project window so I could navigate through my elements easier. Instead of opening a pre comp in a folder and then having to scroll way down to the images, or up to twirl down the folder. I could have each folder open side by side.
