problem with scatter in Element 3d
ali khoshdouni
on Sep 2, 2012 at 9:28:44 pm
When i use two 3d models in 2group in the element 3d plugin i have a problem with the scatter in enable multi ubject for group 2.
in fact i active stopwatch for animation engine then use 2 keyframs in 2 different times. enable the multi-object in group 2 . then increase scatter but not seen any shatter effects in 3d object.
Walter Soyka
Re: problem with scatter in Element 3d
on Sep 3, 2012 at 4:09:16 pm
Multi-object in Element 3D for 3D objects only works if they are pre-fractured. You need to use your 3D app to break your one object into separate pieces of geometry, not a single unified object.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
