Massive audio distortion
Marc Lucas
on Aug 29, 2012 at 11:45:22 pm
Exported a .mov out of FCPX to use in AE I have listen to the file and the audio is perfectly OK. After import into AE (CS5) when playing back the audio is distorted. I checked the audio waveform and the visual distortion is very visible aswell and audible. Its akin to harsh white noise. Any ideas what is going on, this has happened a couple of times now. To remedy I have exported out of FCPX again with the same file name and 'replaced' the footage and it seems to work ok after a second time. Something is not right though.
Roland R. Kahlenberg
Re: Massive audio distortion
on Aug 30, 2012 at 4:04:45 am
From your description it is not clear if it is an FCPX or an AE issue. Have you tried QT Player or an audio app to check the original export from FCPX?
Cheers
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Marc Lucas
on Sep 18, 2012 at 10:10:33 pm
Hi
The file played perfectly OK after export from FCPX its only when it went into AE that I got the audio distortion.
