Export is forcing a resizing that I don't want
Steve Newberry
on Aug 28, 2012 at 2:30:06 am
Getting this warning when trying to export with the MPEG4 codec (CS5.5):
warning:output file will be resized from 1024 x 576 (1.00 PAR) to 720 x 576 (1.46 PAR) to meet format constraints... problem is the client needs it in this codec at that ratio and not resized!
What's going on here? Any way to work with this or around this?
keith mcgregor
Re: Export is forcing a resizing that I don't want
on Aug 28, 2012 at 4:22:22 pm
Sure is, export lossless and transcode to mpeg 4 in an encoding package. Done!
-Keith
Steve Newberry
on Aug 28, 2012 at 4:26:41 pm
Thanks... I juuuust did this. To those following along: I exported lossless and transcoded to mpeg4 in Compressor. Adobe Media Encoder could not do it at a high enough resolution for some reason...
Ben Hartley
on Feb 1, 2013 at 10:35:42 am
I have had this problem but my comps were all exporting absolutely fine and i must have pressed something and now it is exporting in the wrong ratio! How can I put it back to normal so i do not have to convert afterwards???
If it looks good, look at it.
