How to create this EXACT text effect
Atanas Vangelov
on Aug 21, 2012 at 9:07:22 pm
The text effect is 0:31-0:35
clay stearns
Re: How to create this EXACT text effect
on Aug 21, 2012 at 10:35:41 pm
Not sure it's an effect so much as just clever use of many layers. 3D text faked by duping the text layer back in z-space, parented to the top text layer, and set on a wiggle. When the text seems to skew out it's because one or more of those layers are being animated outward and stretched at lowered opacity. Then there are a bunch of textures wiggling around. That's what I can tell, but I'm probably missing something.
Tom Daigon
on Aug 22, 2012 at 12:29:29 am
I agree. I would guess Twitch by Video Copilot was used on multiple layers.
https://www.videocopilot.net/products/twitch/
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
Walter Soyka
on Aug 22, 2012 at 12:34:00 am
I think Clay's advice is right on.
There are a couple ways to do the 3D type in After Effects -- multiple layers separated slightly in Z-space (as Clay suggested) in Classic 3D, extruded type with AE CS6's new ray-tracing renderer, or extruded type with a third-party plugin like Mettle ShapeShifter AE, VCP Element, or Zaxwerks Invigorator.
As for the glitchy-looking effects, those can be added by manually keyframe scale and position or distortion effects, or you can use a third-party effect like VCP Twitch or DigiEffects Damage.
Since you haven't really even asked a question in your post, it's tough to give a better answer than that.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Atanas Vangelov
on Aug 22, 2012 at 6:16:56 am
sorry it's my fault that I didnt explain in detail. I dont want it to be 3D. I just want that shake/wiggle effect. Here is the same effect that I want but not 3D @0:00-0:10
John Cuevas
on Aug 22, 2012 at 1:33:31 pm
Keyframe the scale & position properties of a layer over 10 frames with multiple keyframes. Turn on motion blur for the layer and composition.
Quick example project illustrating the technique: 4574_textblur.aep.zip
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Atanas Vangelov
on Aug 23, 2012 at 10:21:04 pm
Thank you!
