After Effects CS6 Rendering Error
Blake Fluharty
on Aug 17, 2012 at 3:31:31 am
Please Help! Im using After Effects CS6 on a 64 Bit Windows 7 Computer, with the latest QuickTime. Im trying to render a edit i did for a friend with alot of blur and Twixtor (Plugin) and ive rendered files with more of those ram killing blurs before Example:
I rendered it once before the error started happening and it worked but, i saw problems with a plugin so i fixed it and tried to rerender it and I keep getting this error that says "After Effects Error: Rendering Error While Writing to The File c:/...etc (-1610153453)
I figured i had to much blur or something so i changed the brightness and lowered the blur and still the same error. I've tried rendering it with output module H.264 because i think it is the best for HD File Size. My Comp is HDV/HDTV 720 29.97.
PS: The Render Doesnt Even Start I get the error and it fails at 00:00:00.
PPS: The video I linked is not the video I'am discussing, it has yet to be rendered do to this error.
Please Reply ASAP
Thanks, -Blake
© 2018 All Rights Reserved
