Importing Mocha tracking data into CS6
Jimi Lund
on Aug 13, 2012 at 9:17:37 pm
Hi all,
I'm successfully tracking an object (A computer monitor with motion, scale, rotation, shear and perspective all required) and then copying the tracking data to paste onto a text layer made in Illustrator. I'm trying to comp the text onto the monitor.
When I paste the data however, the text just "disappears", as though the opacity has been turned to 0%.
I'm flummoxed as to why this is happening. Am I missing something basic?
Any help would brilliant.
Tudor "Ted" Jelescu
Re: Importing Mocha tracking data into CS6
on Aug 13, 2012 at 10:25:00 pm
Parent text layer to a Null, apply track data to Null, use the Position controls in the text layer to re-position. Most likely your text layer is outside the visible area of your comp.
Tudor "Ted" Jelescu
Senior VFX Artist
John Kaley
on Aug 14, 2012 at 12:55:20 am
Pre-comp your Illustrator file into a compostion that is the exact resolution and frame rate as the tracked shot. Apply your tracking/corner pin data to this layer.
Roland R. Kahlenberg
on Aug 14, 2012 at 9:46:46 am
I'm with John on this one cos if you've tracked perspectives then there is a good chance that you'll want corner-pin tracking data. And when applying corner-pin tracking data, you do not want to apply it to a Null but rather to the insert-layer.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Tudor "Ted" Jelescu
on Aug 14, 2012 at 12:03:58 pm
My bad, I read again the post and I agree with John and Roland.
Tudor "Ted" Jelescu
Senior VFX Artist
Jimi Lund
on Aug 14, 2012 at 12:10:06 pm
Thanks guys,
I'll try those suggestions shortly and let you know how it turns out.
