Luminance Shifts out of AE
Aaron Barton
on Aug 7, 2012 at 2:29:22 pm
Hey Guys,
So I was doing a comp in AE and everything looked fine and then I rendered it out (ProRes4444) and brought it into Final Cut and the footage was noticably darker. I then opened it up in Premiere and it was dark in there as well. I then set up a test and brought in a piece of footage to render out and see if I got the luminance shift again, but this time, no shift. Could it possibly be something in the comp that's causing the shift or is it because I'm exporting out as a Quicktime?
Aaron
Tudor "Ted" Jelescu
Re: Luminance Shifts out of AE
on Aug 8, 2012 at 8:11:56 pm
Are you using color management? Is the profile you use the same in all instances?
http://help.adobe.com/en_US/aftereffects/cs/using/WS61A9D13D-919A-4010-A3A2...
Tudor "Ted" Jelescu
Senior VFX Artist
