Can't see anything in viewer window. Just black!
dale cullis
on Jul 30, 2012 at 9:48:03 am
I know this has been asked before, but none of those solutions seem to work. I am completely new to after effects, I know I must just have a setting wrong somewhere but I can't figure it out and i've looked online a lot.
I import and image to a new project, then put it in a new composition, but I can't see anything.
Caps lock is off, wireframe is unchecked, and I have reinstalled.
I'd really appreciate any advice :) Thanks
P.S. Even if I make the composition background like bright green, and add nothing to it, the background still won't show in that viewer
Walter Soyka
Re: Can't see anything in viewer window. Just black!
on Jul 30, 2012 at 1:47:38 pm
Are you looking at a comp viewer for that composition, or perhaps a layer viewer, footage viewer, or locked comp viewer?
A screenshot showing your full UI will help us diagnose your problem.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
dale cullis
on Jul 30, 2012 at 2:15:47 pm
Hi Walter, I'm sorry, I just attached the screenshot but not sure it has come, just in case: http://f1.creativecow.net/4454/my-current-window It is here :) thankyou
Walter Soyka
on Jul 30, 2012 at 4:19:14 pm
Nothing is jumping out at me -- can you File > Collect Files, zip up AEP and the PNG and post the whole project?
Walter Soyka
dale cullis
on Jul 30, 2012 at 4:52:08 pm
http://f1.creativecow.net/4457/curtains-project-file?uploaded=file Here you are, thanks for helping, I am literally pulling hair out here!
Walter Soyka
on Jul 30, 2012 at 5:13:06 pm
Looks fine here. Must be something wacky going on...
I recommend you first reload the footage (right-click in the project panel, choose Reload Footage), and failing that, clear your caches with Edit > Purge > All Memory and Edit > Preferences > Media & Disk Cache > Empty Disk Cache.
Walter Soyka
dale cullis
on Jul 30, 2012 at 10:59:17 pm
None of that worked. Really can't see what's wrong. When I purged all memory, the image flashed on the viewer for a second and then back to black.
Walter Soyka
on Jul 31, 2012 at 2:12:00 pm
[dale cullis] "When I purged all memory, the image flashed on the viewer for a second and then back to black."
Well, that's really strange. You purged the disk cache, too?
Can you see other PNG files? Can you see that specific image if you convert it to another format (PSD or TIF) first?
Walter Soyka
Kevin Reiner
on Jul 31, 2012 at 3:34:41 pm
Try this.
As Walter suggested, change the file to another image format. Then reset AE prefs. To restore default preference settings, hold Ctrl+Alt+Shift (Windows) or Command+Option+Shift (Mac OS) while the application is starting.
Then start a brand new project, new comp, and see if you still have the problem.
Hope you get it figured out,
Reiner
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23" flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
dale cullis
on Jul 31, 2012 at 8:16:01 pm
Hi, yes I purged the cache, and i've tried it different formats. I reset the prefs, and then started a new project, and re-imported into a new comp, and still nothing shows up in the window?
I really can't see why this is happening
I just tries importing .mov aswell just to see if it would work, and it is just a black screen for that aswell
Kevin Reiner
on Jul 31, 2012 at 9:13:55 pm
Are you able to see other image files? Does it appear that its a problem with just this image, or is there a systemic problem within AE of not seeing any images?
32GB Memory
ATI Radeon HD 5770
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
dale cullis
on Aug 1, 2012 at 8:26:02 am
Hi, I can't see any images or videos. They're there, and flash up really quickly every so often if I change the zoom etc but then it is gone again
Kevin Reiner
on Aug 1, 2012 at 1:11:15 pm
Hmmmm...
That might be pointing to something outside of AE. Maybe graphics card or something. Can you give your machine specs?
-Reiner
32GB Memory
ATI Radeon HD 5770
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
dale cullis
on Aug 1, 2012 at 7:00:05 pm
Hi Reiner,
I'll be honest I know nothing computer related really, I have a Dell studio laptop that's 2-3 years old. I don't know it's specs, but I save most things to external hard drive so it should have quite a bit free space. It handles things like premiere pro no trouble at all?
Jessica Poutous
on Oct 11, 2012 at 4:27:12 am
Hey there,
I know it's been a few months, but I'm having the exact same problem. Did you ever figure out a solution?
dale cullis
on Oct 11, 2012 at 8:55:40 am
Hello Jessica,
no I didn't i'm afraid, I installed it on a friends laptop though and it worked perfectly.
I tried everything, and despite premiere pro and photoshop etc working perfectly on my laptop, after effects just wouldn't work, so I assume I don't have enough RAM, I only have 3GB, and I have plenty of memory. I am guessing it's down to my laptop not being able to handle it though :)
Jessica Poutous
on Oct 12, 2012 at 2:49:41 am
Thank you for the quick response. I was really hoping you had a magic cure!
I talked to Adobe today for over an hour and they confirmed that my RAM, graphics card, etc., are more than adequate. They only issue they could think of is that I'm running Windows Vista. I'm going to try upgrading to Windows 7 and see if that helps. I'll be sure to let you know either way.
Thanks again!
dale cullis
on Oct 12, 2012 at 10:18:03 am
OK, yes thanks, i'd love to know if you find a way to fix it :)
Nicci Wymond
on Oct 17, 2012 at 11:53:23 pm
Hi Jessica & Dale
I stumbled upon your dilemma after a long search while trying to figure this same problem out that I too was experiencing on my Windows Vista 64 PC...eventually after a lot of unistalling and re-installing a tried updating my gpu (graphics card) driver and it was then that I got my comp window in after effects to work! Hope this helps;)
Jessica Poutous
on Oct 18, 2012 at 2:44:59 am
Oh my gosh!! That worked!!! I don't know why I didn't think of that before!
Thank you so much! You are a lifesaver! :-)
~Jessica
