Rendering problems on the size of 3840x1080 (QTH264)
Dody Soemantri
on Jul 24, 2012 at 4:17:28 pm
Hi There,
I work using AE for matrix display 1x2, so the size is 3840x1080 (1 display = 1920x1080).
Question 1: I render using QT H264, why the results can not be fully fit my expectations (3840x1080)? I was hoping the QT can be unlimited size.
Question 2: I also tried with H264 codec for mp4 to output 3840x1080 (successfully). But because the system matrix machine i have to use (default) WindowsMediaPlayer, why when I play just appear blank? But when I re-render with half size (1920x540) WMP is running normally.
Question 3: how to make the composition look hi-res (crispy) with maximum visibility of 2 meters (the size of the above)
Note: I am using Win7 with the i7 processor, AE 5,5, Samsung display 50 inch
© 2018 All Rights Reserved
