AE Problem with rendering
Frank Walter
on Jul 17, 2012 at 11:32:24 am
Hey everybody
I have a Question. I'm using a Nikon D800 and my testvideo was shot in 720p with 60 frames/s. I editet it with a twixtor effect, some color correction and brightness/contrast adjustments and then I added a mojo effect and a little blur. Then I rendered it by clicking 'make movie'. At the end of rendering it had a length of 24 sec but the size was about 4GB. Is that possible? And cause of this enormous size, my computer wasn't able to even play the video, means it lagged so hard that it was unwatchable.
My question now. Is this size realistic? If yes, how can I reduce it, without harming the quality?
Thanks for your help
Regards
Frank
John Cuevas
Re: AE Problem with rendering
on Jul 17, 2012 at 11:45:27 am
FAQ: Why is my output file huge, and why doesn't it play back smoothly in a...
The best way to reduce file size is to take the uncompressed file into a compressor(Media Encoder)and choose a compression that will work best for your needs.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Frank Walter
on Jul 17, 2012 at 11:48:05 am
woah, thanks loads !!
