Masked on an unwanted place
Kaan Yilmaz
on Jul 16, 2012 at 1:11:18 am
I'm having a problem while rendering a short video on Adobe After Effects.
I've been using Rotobrush, so I could remove the background of my video, but when I watch my rendered video, there is a "hole" (masked) on the middle of my video
This is a screenshot of how my rendered video looks like:
(It's the same in VLC player)
And in Adobe After Effects, there is no masked hole, as you can see:
How do I get rid of that masked hole?
Thanks in advance,
070ky58
Darby Edelen
Re: Masked on an unwanted place
on Jul 16, 2012 at 2:40:19 am
Not sure that this will fix the issue you're having, but always make sure that you paint with roto brush at Full resolution. Note the warning at the bottom of your layer viewer. Switch back to the composition viewer and make sure that you're set to "Full" resolution.
Darby Edelen
Kaan Yilmaz
on Jul 16, 2012 at 1:08:05 pm
Hi Darby,
It was already set to Full Resolution, so that isn't the problem.
Thanks for replying, though.
070ky58
Kaan Yilmaz
on Jul 16, 2012 at 1:13:19 pm
Nevermind, I got it solved.
It turns out I can edit that hole away, when I press Stop while its rendering my video.
