should be a simple expression
David Markey
on Jul 11, 2012 at 10:14:09 pm
Hi All,
Need help with a simple expression. I have an Offset effect on a layer. I want the x value of the shift center property to stay constant, but I want the y value to increase over time.
shouldn't it be something like this?
[value, time*100]
that doesn't work. I should be able to figure this out, but my brain isn't working.
Darby Edelen
Re: should be a simple expression
on Jul 12, 2012 at 12:07:16 am
[David Markey] "[value, time*100]"
Value is a vector/array on a position property. You have to specify which component you want:
[value[0], time*100]
Darby Edelen
