If statement only executes once - Expression problem
Jeo Greko
on Jul 10, 2012 at 5:47:19 pm
So I am trying to make an expression have an on and off duration, all my math is good as far as I can tell but one of the if conditions only runs once. If I duplicate the if it will work as many times as I copy it, any help is really appreciated.
t = time*24;
period=10;
holdTime=2;
loop=period+holdTime;
if(t>=loop) t=t-loop;
if(t/period>=1) 100 else 0;
The if that doesn't repeat is "if(t>=loop) t=t-loop;" The weird part is the second if will always execute.
Walter Soyka
Re: If statement only executes once - Expression problem
on Jul 10, 2012 at 7:29:58 pm
Expressions have no memory; they are evaluated anew on each frame. The value of t is not remembered from one frame to the next, so this expression will not constrain the value of t to a single cycle from 0 to 12.
If you want the value to cycle, you can use the modolo (%) operator and so-called "clock arithmetic."
More simply, you could just set some keyframes and add the expression loopOut("cycle") to have them repeat over and over.
What exactly is it you are trying to do?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Jeo Greko
on Jul 10, 2012 at 7:42:09 pm
I am just trying to make a preset that is off for 10 frames than on for 2 frames. So if you apply this to opacity it will have a value of 0 from frames 0-9 and a value of 100 for frames 10 & 11, then to have that repeat.
I don't want to use keyframes because this is a constant issue I face and if I can just update the numbers and have it update rather than add new keyframes and loop it would save me a huge amount of time.
Walter Soyka
on Jul 10, 2012 at 8:00:02 pm
[Jeo Greko] "I don't want to use keyframes because this is a constant issue I face and if I can just update the numbers and have it update rather than add new keyframes and loop it would save me a huge amount of time."
Right -- the idea is to make a couple hold keyframes and add an expression.
Create a keyframe at frame 0 at 100 opacity; right-click it and Toggle Hold Keyframe.
Advance to frame 10 and add a keyframe with the value 0.
Advance to frame 12 and add a keyframe with the value 100.
Alt-click the opacity stopwatch and enter the following expression:
loopOut("cycle");
To modify the timing of the loop, you need only modify the timing of the three keyframes; loopOut will work the looping magic for you.
Walter Soyka
Walter Soyka
on Jul 10, 2012 at 8:05:27 pm
Or, if you really want an expression:
myTimeInFrames = timeToFrames(time - inPoint);
period = 10;
hold = 2;
myLoopTimeInFrames = myTimeInFrames % (period + hold);
if (myLoopTimeInFrames < 10) 100 else 0;
The modulo operator (%) returns the remainder after integer division. With this constants, the value cycles from 0 to 11, then repeats.
FYI, there is an AE Expressions forum [link] here.
Walter Soyka
Jeo Greko
on Jul 10, 2012 at 8:21:20 pm
Hey wow,
this is exactly what I was aiming to do, thank you very much for your time.
I will make sure to post on the expression forum next time.
Walter Soyka
on Jul 10, 2012 at 9:09:02 pm
Minor error in the above! I left a constant value in the last line. The expression SHOULD read:
period = 10;
hold = 2;
if (myLoopTimeInFrames < period) 100 else 0;
Glad this helped.
Walter Soyka
