Problems with importing .mov DNxHD converted file (from 7D H264) into After effects CS5
Romain Colonieu
on Jul 7, 2012 at 7:50:43 pm
Hello,
I've read in forums that the best quality you would get after conversion from H264 files from Canon 7D is with Avid DNxHD
I'm having a problem here with importing some .mov DNxHD converted file (from 7D H264) into After effects CS5.
After effects doesn't recognise the file, it mention some "After Effects error: File cannot be imported, file is damaged or unsupported"
I have just installed the codec, and now "Mpeg stream file" as well as "Foxreal" show up the thing but I can get the file imported on Ae.
I don't know what to do,
it's my first post here, I know it should work but I don't have the answer and can't get it on google.
Many thanks,
Romain
Romain Colonieu
Re: Problems with importing .mov DNxHD converted file (from 7D H264) into After effects CS5
on Jul 7, 2012 at 8:04:08 pm
I'm on PC by the way,it might help!
Romain Colonieu
on Jul 8, 2012 at 12:27:05 am
Problem solved, I just had to reboot and Ae found the codecs ;)
