temporal wiggle expression that only jumps forward in time
jim bachalo
on Jun 29, 2012 at 8:28:47 pm
How would one write a temporal wiggle expression that only jumps forward in time..or something
even better to achieve the following....
I have my 2 position keyframes set for an object that is dragging along the floor being pulled by a string
which makes a smooth motion from A to B.
In real life it would stutter somewhat do to the resistance of the floor...
The temporal wiggler will jump it back & forth but I only want it to move forward.
I could manually insert many inbetween keyframes and then drag them left and right but wonder if their was an easier expression...since I will be doing many of them.
Thanks in advance!
Local is the new global
jim bachalo
Re: temporal wiggle expression that only jumps forward in time
on Jun 29, 2012 at 11:13:35 pm
in working on it, I realize I need a random - move hold -move hold, between two keyframes..not
a temporal as I am aiming for more realism and not stop motion..
