View Transform and Layer Styles in separate window
Dustin Parsons
on Jun 28, 2012 at 9:17:47 pm
Is there a way to view the Layer Styles or Transform options of a selected layer in a window other than the timeline? I'm basically looking for a way to have it work like the Effects and Presets window so I can view all the info without having to drop down so many arrows.
Brian Charles
Re: View Transform and Layer Styles in separate window
on Jun 28, 2012 at 9:21:46 pm
There's no way to see Layer Styles (or for that matter Shape properties) other than the Timeline, however you could apply the Transform Effect (Effects > Distort > Transform) which gives you access to all geometrics and more.
Dustin Parsons
on Jun 28, 2012 at 9:47:49 pm
I was hoping that wasn't the case. I wasn't aware of the Transform effect though, I might give that a shot. Thanks!
Dan Fredley
on Jun 29, 2012 at 5:40:56 pm
A couple of other suggestions:
  • You can Cmd/Ctrl+click any arrow in AE to open all child arrows in one click.
  • In the timeline search bar, you can open the properties you want to see by adding a comma in between search criteria. For example, "pos, rot, sca, drop" opens position, scale, rotation and drop shadow properties.
