Smooth Flickering
Allen joaquin
Smooth Flickering
on Jun 27, 2012 at 9:29:34 am
Hi, in a Project i've wanted to create a sort of flicker using gaussian blur and Brigtness and contrast, I've thought about using The loopout script. "loopOut(type = "pingpong", numKeyframes = 0)" with some keyframes but i was wondering if there is any way i could make it go faster then the actual speed it has.
Because the flickering it's not as fast as i'd want it.! How could i fix this? Or is there any way appart from dong keyframe by keyframe? because it's a huge comp.
Thank you,
Walter Soyka
Re: Smooth Flickering
on Jun 27, 2012 at 1:23:57 pm
You could keep the loopOut expression and adjust the keyframes (select all keyframes, then Alt-drag the last keyframe towards the first to move all keyframes proportionately).
You may also be able to precomp your flickering and use time-remapping, depending on how your project is built.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Allen joaquin
on Jun 28, 2012 at 12:09:53 am
They keyframes dosen't really matter i belive cause i got them exactly 1 frame from each other and it dosen't goes as fast as it should. yeah i thought about time remapping too. but i was wondering if there was another way..
