Dissolving Flourish - PLEASE respond
Sean Morton
on Jun 21, 2012 at 10:21:57 pm
i need to have a dissolving chase to an arrow on screen.
In one layer i have a arrow flourish. The arrows comes out of screen and draws across screen. I want the arrow dissolve the tail after its printing on screen.
So i duplicated the same arrow flourish, moved it over in the time line with the same dimensions. I added silihoette luma as the blending mode. This accomplished the arrow dissolving i wanted. It also cut a whole in my background plate while i was at it. Need to keep the background plate the same
Anyone have any suggestions
Sean Morton
Roland R. Kahlenberg
Re: Dissolving Flourish - PLEASE respond
on Jun 21, 2012 at 10:36:00 pm
Silhouette Luma will cut a hole for all layers below. Thus, you have to breakdown your routine into two separate comps - one with the silhouette and its intended effect and another comp where you place a copy of the silhouette comp over your desired background.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Sean Morton
on Jun 21, 2012 at 11:00:08 pm
Thank you Roland
u solved the problem... I am still getting a outline around the arrow that i can't get rid of.. Tried
making the luma layer bigger but it actually made the problem worse. Any suggestions??
Sean
on Jun 21, 2012 at 11:09:48 pm
Sean, without looking at the comp, it's kinda difficult to say what's causing an outline to appear. Perhaps you can try Silhouette Alpha instead. And if that doesn't work, post screencaps of your timelines and comp panel.
Cheers
RoRK
