Big Bigger Biggest
Jonny Webb
Big Bigger Biggest
on Jun 20, 2012 at 10:05:45 am
sorry if this is in the wrong place, i did search various terms.
So have you seen the TV show Big Bigger Biggest. Its very popular, partly i'm sure, for the cool animations. They have a blueprint look and feel, just wireframes, but smoothly animated.
And i've been asked to put one together "if it doesnt take a week".
At work i have access to CS6 AE, CS6 PPro, and 3DS Max, maybe others.
Has anyone made such an animation? What did you use?
Anyone come across a tutorial of the above?
Thanks, Jon
Walter Soyka
Re: Big Bigger Biggest
on Jun 20, 2012 at 2:25:26 pm
[Jonny Webb] "So have you seen the TV show Big Bigger Biggest. Its very popular, partly i'm sure, for the cool animations. They have a blueprint look and feel, just wireframes, but smoothly animated. And i've been asked to put one together "if it doesnt take a week". At work i have access to CS6 AE, CS6 PPro, and 3DS Max, maybe others."
Those are animated 3D models, and they'd have to be done in a 3D application like Max.
How long it will take to do depends on how well you know your 3D app, how good your modeling skills are, and how complicated the object you have to model is. You may be able to save time by finding a stock 3D model for the object you need on a site like TurboSquid.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Kevin Reiner
on Jun 20, 2012 at 6:08:49 pm
Trapcode Form might be able to do some cool things, but you would still need a 3D model created in 3DS Max or from TurboSquid as Walter suggests.
http://www.redgiantsoftware.com/products/all/trapcode-form/examples/
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23" flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
Tudor "Ted" Jelescu
on Jun 20, 2012 at 5:31:02 pm
Depending on what exactly you need to include in your title sequence- what kind of objects you need + text, you may be able to use a plugin like ShapeShifter. For more complex 3d objects you can also use Zaxwerks Invigorator Pro. Of course the most direct way would be to do it in a 3d app, but I think AE can achieve a similar result using only 3rd party plugins like the one I mentioned above.
Tudor "Ted" Jelescu
Senior VFX Artist
Jonny Webb
on Jun 21, 2012 at 9:15:30 am
Thanks Guys,
i need to make a train on tracks scene.
A very simple train (bullet-ish) moving a dozen trainlengths.
As i have access to 3ds max, i'd like to use it. I've done a bit a few years back and enjoyed the program/interface/workflow/etc.
i guess i better research Max tutorials and libraries.
