Error When Trying To Render Plugin
carlos dee
on Jun 18, 2012 at 6:27:16 am
im trying to use the fractal noise to cover the floor and at least get rid of those sides, im doing that by increasing the scale, i keep getting this error when im trying to render this is using fxfactory plugin advanced blurr how can i fix it, my composition settings im using are 1920x1080 and all the comps im working with are also 1920x1080, i scaled it down to 100% and i still keep getting this error when trying to render thanks!
Walter Soyka
Re: Error When Trying To Render Plugin
on Jun 18, 2012 at 7:08:46 pm
AE's render order is METL -- masks, effects, transforms, layer styles. You should be able to scale up past 2K because scaling occurs after effects are rendered.
Do you have any solids that are larger than the plugin's 2K dimension limit? Or perhaps the blur effect is extending the layer bounds?
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
