Split screen frame jumpiness/edge jitter (imported premiere sequence in AE)
john titor
on Jun 16, 2012 at 3:42:31 pm
Essentially I have a sequence in Premiere CS4 which I've imported into AE CS4. Basically I had an issue a day or two ago where it was washed out, that problem seemed to vanish for whatever reason although I think it may be related in some sense to the current problem I'm having. In my sequence I have shots which are in split screen. When I render them out from premiere they're fine. However rendered from AE there is edge jitter around the borders of the various frames and some frame jerkiness in the 9 split screen shot. How would I go about fixing this?
Tudor "Ted" Jelescu
Re: Split screen frame jumpiness/edge jitter (imported premiere sequence in AE)
on Jun 16, 2012 at 5:30:39 pm
You need to provide more information- what is the size, frame rate and color space you are using? Progressive or interlaced footage? when you render out, do you keep the same specs? Is all your footage the same? Why are you rendering from AE? Any effects you applied in AE?
Maybe posting a short render will help as well.
Tudor "Ted" Jelescu
Senior VFX Artist
