cleaning and retouching complex shot
Chris Ten
on Jun 15, 2012 at 7:43:40 am
Hello
I have the job to clean close-up shots of luxury watches. I have to remove dusts, scratches and fingerprints.
So far so good. But there are some shots which are a bit complicated to handle with the clone tool.
For exemple this shot:
The dust between the hand of the watch and the screen is full of small bright dust. When i use the clone tool it looks great on each frame but when i play the video you can clearly see it has been "worked on".
Is there any technique or advice you could share on this matter? That would be great because i have no clue how to make it look perfect.
Thanks for your help
