From line to text.
Filippo Guerra
From line to text.
on Jun 12, 2012 at 6:44:38 am
I'm trying to transform an horizontal cable wire (basically, a line) into a text.
something like this
4278_senzatitolo1.png.zip
canon someone post some tut or explanation to do this?
thanks
Tudor "Ted" Jelescu
Re: From line to text.
on Jun 12, 2012 at 7:40:32 am
I am sure this can be done several ways, the question is how do you want the transition to look like? Is it a morph or does the line animate to form the letters one by one? Is the file you posted the final look? Let us know and we can provide better feedback.
Tudor "Ted" Jelescu
Senior VFX Artist
Filippo Guerra
on Jun 13, 2012 at 6:58:32 am
I want the wire to form the word in the middle, writing letter by letter...
the file I've posted It's not the final look, i'm trying to get a continuous word, I'll post an updated example!
Tudor "Ted" Jelescu
on Jun 14, 2012 at 6:35:35 am
I think you can either use animated masks to ceate the illusion or use a path that you animate to form the text and apply a stroke to that. With the path it's easier if you animate in reverse- start with the final position, draw the line with the text formed and then work backwards to unravel and flatten the line. The trick is to design a look that will allow you to have the text formed by one continuous line.
Tudor "Ted" Jelescu
Senior VFX Artist
Amin Rodriguez
on Sep 10, 2012 at 2:55:06 pm
i have been looking for the same thing for about a year now... this is my problem...
hope someone knows the answer.
