Script to remove keyframes that are the same
James Peres
on Jun 11, 2012 at 12:00:30 pm
Hi, I am having a little trouble figuring out how to go about a script to clean up the Convert Expressions to Keyframes process. I basically end up with a lot of keyframes that are essentially the same (the result of the hold keyframe). I export XML using those keyframes to having a lot of unnecessary keyframes slows things down. Is there a way to remove keyframes that don't change value?
I've come across JD_SmartBaker.jsx, but no matter what I set the tolerance to it doesn't remove many frames.
Mac Pro 4,1 Quad Core 2.66
Roland R. Kahlenberg
Re: Script to remove keyframes that are the same
on Jun 11, 2012 at 7:09:40 pm
I don't know of a script but you can right-click on a KF and choose, Equal KFs to select all KFs that are of the same value as the KF where your Timeline Indicator is parked at.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Dan Fredley
on Jun 21, 2012 at 1:56:43 am
http://aescripts.com/smart-baker/
James Peres
on Jun 21, 2012 at 5:58:10 pm
Hey! Thanks for the reply. I tried smart baker and it doesn't work: if I use a threshold high enough to remove equal keyframes, it also begins removing animation curve frames. I only want to remove keyframes that are equal.
James
Dan Fredley
on Jun 21, 2012 at 6:43:02 pm
Try setting the threshold to 10.
