AE CS6 Camera Tracker with Optical Flares
Clarke Flippo
on Jun 7, 2012 at 12:32:17 am
Hopefully a pretty simple question. Can you use AE CS6 camera tracker for tracking info instead of motion tracker? I want to parent an optical flare to a null created from camera tracker. If so, how is it done?
Clarke
Roland R. Kahlenberg
Re: AE CS6 Camera Tracker with Optical Flares
on Jun 7, 2012 at 4:29:31 am
1) complete your track with AE's 3D Camera Tracker
2) select a solve point(s) and create a camera & a null
3) create a light
4) Shift+Parent (new technique in CS6) the light layer to the null
5) create a solid for VC OF and set it to use the light
Ah, just realized that you didn't specify the type of lens flare. If it's a 2D-only Lens Flare, the follow steps 1 & 2 above, then
3) create a black solid and apply your lens flare
4) apply the following expression to the flare's generating point -
TargetLayer = thisComp.layer("Track Null 1");
TargetLayer.toComp([0,0,0])
5) set blending mode of the flare solid to screen or add
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Clarke Flippo
on Jun 7, 2012 at 3:16:28 pm
Yes I forgot to specify it is a 2D flare. I'm not sure what you mean by the flare's generating point. I don't see that in the effect controls. I'm pretty new to optical flares.
on Jun 7, 2012 at 3:33:06 pm
If you're using Video Copilot's Optical Flares effect then just follow the steps I've provided.VC's OF has a Positioning Mode property that allows you to apply a flare to an AE Light.
The tutorials from VC for OF are really good. You should spend time on those if you want to get the best out of the effect.
HTH
RoRK
