CS6 Performance Impressive!
Brian Charles
on Jun 6, 2012 at 12:05:02 am
I've just rendered a file in CS6, wow. CS5.5 rendered in 4 hrs 20 min, CS 6 rendered in less than half the time. Holy Shxt!
I suspect Steve Forde (formerly GridIron Software) had something to do with this. As a former Nucleo Pro user I'm really impressed with the memory management and performance of CS6.
MacPro 12 core 32 GB RAM. OS 10.6.8
Roland R. Kahlenberg
Re: CS6 Performance Impressive!
on Jun 6, 2012 at 2:12:58 am
It is easily the best software upgrade I've ever made.
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Spencer Tweed
on Jun 6, 2012 at 4:25:57 am
Wow! What kind of disk is your performance cache on? And what GPU do you have?
- Spencer
on Jun 6, 2012 at 9:44:18 am
Here's some good info on render times with various hardware-supported ray-tracing with CS6 -
https://twitter.com/rendernyc/status/208421894792298496/photo/1/large
However, there are other considerations as to the type of comp/layer setup. But the results do give a good indication as to which cards to avoid and which ones give the most bang for the buck!
HTH
RoRK
Kevin Reiner
on Jun 6, 2012 at 1:42:41 pm
Good to hear Brian,
Makes my upgrade decision earlier. As far as multiprocessing, does AE 6 do all of the guesswork for you in regards to preferences?
I just finished a huge project with AE5 that was helped tremendously by multiprocessing, but at times I felt I was spending more time figuring out the optimal preference settings rather than creating.
Reiner
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23" flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
Brian Charles
on Jun 6, 2012 at 3:19:23 pm
[Kevin Reiner] "As far as multiprocessing, does AE 6 do all of the guesswork for you in regards to preferences? "
I had mine set to use 7 processors allocating 3GB to each.
I looked at Activity Monitor during the render, RAM was freed quickly and reallocated. Cache was set to 40 GB on a RAID 0 (2 x 1TB 7200 rpm drives).
jeffrey broullire
on Jul 3, 2013 at 11:00:44 pm
hello, @ Brian Charles (or other users of nucleopro3)
don't know if this will work
but can you reply back stating where to 'install'
gridiron nucleo pro 3 licenses please...
thanks in advance, have a good day, j
