Change orientation of corner pin in mocha
Nick Shaw
on Jun 2, 2012 at 6:59:10 pm
So i did a track in mocha with adjustments and all that and when I import the tracking data to after effects to an image I want to add to a tablet the corner pin is translating the horizontal as vertical and the vertical as horizontal. Is there a quick way to fix this (like rotate all the corner pins to the left) or something? Let me know if this makes sense or not.
Roland R. Kahlenberg
Re: Change orientation of corner pin in mocha
on Jun 2, 2012 at 8:53:43 pm
Ideally, you'd go back into mocha and re-apply the Surface. If you want to mess about in AE, then apply the Distort>Transform effect, place it on top of the corner-pin and make your transform operations from there.
This may or may not work - it all depends where you're at and where you want to end.
If you're comfortable with pick-whipping to create Expressions, then simply pick-ship the four corner-pin points to re-align the orientation of your image.
You could also precomp the insert layer and set it assbackupwards. ;-)
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Dan Fredley
on Jun 21, 2012 at 8:09:17 pm
Use the rotation option on this script:
http://aescripts.com/cornerpinner/
