Tracking a moving garbage matt.
murray coulter
on May 30, 2012 at 6:50:44 am
Hi all,
Here is my 2 shots both shot on a tripod without moving it. They are both panning shots and i am wondering if it s possible to matt out the windows in the internal exposed shot to show the external exposures shot underneath and have them both panning..
I can do it fine on a static shot of both exposures but i am struggling to make it work with a panning shot.
Any Idea's?
Thanks for your help.
Murray.
Dan Fredley
Re: Tracking a moving garbage matt.
on May 30, 2012 at 6:29:47 pm
If I understand correctly, you can track the replacement window in MochaAE--stabilize the corner pin using MochaImport+, then track the stabilized window onto your background plate with a normal corner pin.
Dan Fredley
murray coulter
on May 30, 2012 at 8:03:31 pm
Thanks Dan, i will download the trial of Mocha and give it a go..I'll keep you updated..
