AE CS6 11.0.1 CUDA BENCHMARK PROJECT - test your graphics cards!
Teddy Gage
on May 26, 2012 at 7:12:58 pm
Hey guys trying to get some data on fastest graphics cards for AE - I came up with a benchmarking project that stresses the GPU to 100% and already got surprising results:
on win 7 core i7 3930K @4.7 ghz / 32 GB RAM
BENCHMARK AVAILABLE HERE - http://www.teddygage.com/AEBENCHCS6/
you will need 900MB drive space and the new CS6 11.0.1 patch
GTX 680 (2 GB VRAM) = 6 minutes 11 sec to render
GTX 580 (3 GB VRAM) = 5 minutes 42 sec to render
so the GTX 580 with 3GB memory is FASTER than the GTX 680 with more CUDA cores. interesting
looking for testers with GTX 590, GTX 680 (4GB RAM) and GTX 690. Also any quadro cards that work
THANKS
John Cuevas
Re: AE CS6 11.0.1 CUDA BENCHMARK PROJECT - test your graphics cards!
on May 27, 2012 at 2:17:56 am
As I'm deciding on my new system(and video card) I'd be very interested in seeing the results.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Juan Salvo
on May 27, 2012 at 6:34:44 am
We've seen the same results in Resolve, where the 580 is on par or slightly ahead with regards to CUDA processing. It has to do with a shift to a software task processor in the Kepler systems. The 690 may out perform the 580. But ofcourse so would the 590.
Hopefully the Kepler based Quadros will have a hardware task controller and improved CUDA performance.
Online Editor | Colorist | Post Super | VFX Artist | BD Author
http://JuanSalvo.com
Erik Mickelson
on May 30, 2012 at 5:12:10 pm
Nope, not happening on my mac.
I stopped the render after 15 minutes. Time remaining was over 7 hours. Obviously there is zero Open CL support(cannot select GPU option). Specs are in my sig.
CrippleBook Pro 2.3Ghz i7, 16GB ram, Lion 10.7.4, FCPStudio 3, Adobe CS6. QT 7
Mathew Lear
on Jun 6, 2012 at 9:58:44 pm
Hey guys, just tried this on my mac and getting slightly faster speeds with my GTX 480 5 minutes 41 seconds - Had to make a few edits to supported cards list as shown here http://www.tonymacx86.com/viewtopic.php?f=15&t=62702&start=0
Ben Jones
on Jun 8, 2012 at 4:14:13 am
System 1:
3930K (stock) (no idea why it is, it must have reset itself)
470 GTX (448 CUDA cores)
8min 17 sec
System 2:
2 x 8 Core Xeon E5 Sandy Bridge @ 3.3GHz (16 Cores / 32 threads)
Quadro 4000 (256 CUDA cores)
17 minutes 24 sec
conclusion: Test seems completely processor independent
CUDA cores are key, Quadros are useless at raytracing!
Thanks Teddy... you just answered a question that has been bugging me for months.
Q: Are Quadros worth the money?
A: Not even slightly!
Mathew Lear
on Jun 8, 2012 at 8:26:01 am
Quadros are definitely worth the money if your working in a engineering environment with multiple workstations and need support from nvidia.... But for home users and single user environments then geforce works just fine and in most cases better.....
John Macedo
on Jul 3, 2012 at 1:30:20 am
Ben,
These are VERY telling scores you've recorded here... and here's another to spin your head.
I am running an Intel i7 920 @ 4.2GHz (52deg C w/ Coolmaster V8 fan)
with 12Gb of tripple-channel ram at PC16000 speed.
I was doing a project in Adobe Premiere Pro and noticed the rendering was TERRIBLE and this with a GTX580.
I remember this exact computer being faster, only 8 months prior, when I had my GTX295 in it.
Guess what? Using the Mercury Hack... Sure enough, the GTX295 was BLAZINGLY faster, I could bring up apps in the background, surf and more while I rendered.
There's something to be said for Dual-GPU and DEFINITELY something for having a memory-interface width of 896-bit. CUDA scores are only 480 and I am SO tempted to get a GTX690 because of the high scores it boasts... but after reading your article, I think I'll wait!
Thanks for doing this test man!
Mark DeHerrera
on Jun 11, 2012 at 6:29:51 pm
Question about your test machine. Did it use pci 3.0? Because i imagine that may give an edge to the 680 under those circumstances sicne the 680 supports 3.0 and the 580 does not. However, if it was PCI 2.o then this is still a valid benchmark for those with 2.0 slots on their motherboard.
Mathew Lear
on Jun 12, 2012 at 9:18:05 am
PCIExpress 2.0 has more than enough bandwidth for a 680.. There would be no visible difference unless you were rendering with 3 of these cards......
Mark DeHerrera
on Jun 12, 2012 at 2:26:57 pm
Good point, I was thinking it may make a difference but now that you said that I agree with you.
Also I ran the test on my quadro 2000 , soon to be replaced with a 680, and it rendered that test in 28min, 11sec
Roy Foliente
on Jun 19, 2012 at 6:41:02 am
Is it the amount of RAM that makes a difference? I wonder how a Maximus combo with a Quadro card and Tesla C2075 with 6GB of RAM would fare?
Juan Salvo
on Jun 19, 2012 at 7:26:05 am
I've updated my post with benchmarks for Maximus & q6000 as well as others.
http://forums.creativecow.net/readpost/2/1019643
It's not pretty for the quadros.
Eric Bowman
on Jun 25, 2012 at 5:20:25 am
Thanks for doing the benchmark guys. I only wish I would have waited to buy my ATI 5870.
SO this doesn't help much, but here's what you guys can expect with a 4,1 model Mac Pro with the following specs:
- 2.4Ghz 8 core Xeon (2009?)
- ATI Radeon HD 5870 (1GB Ram)
- 24GB Ram
- Rendering to a Hitachi 2TB 7200RPM SATA drive
GRAND TOTAL RENDER TIME! 5hours and 45minutes. Ugh. That was using the BGRenderer plugin too.
I just bought the 5870 for Maya and I'm on 10.6.8. Guess it's time to get a MacVidCards nVidia GTX 570 and Lion. Wondering if it would be better to wait until Mountain Lion ships?
Eric Bowman
assemblycreative.com
ericsbowman.com
Geoff Saville
on Jul 30, 2012 at 12:02:07 pm
Hi All,
I've been looking for a way for AE CS6 to pick up my GTX590 on this one, then I finally realised it's just a matter of adding it to the supported cards list within the install directory.
I ran the benchmark and ended up with 4min30sec. I'm on PC, I'm nit sure if this was a MAC only experiment.
Interesting all the same I guess.
wouter abbestee
on Sep 12, 2012 at 3:04:02 pm
About 8 minutes on i7 3770K with a 660 TI 2GB videocard.
Just a question, the reflections look pixelated. Is that normal?
Rob Bach
on Nov 18, 2012 at 3:48:15 pm
I got the same time with same basic system MSI GTX 660Ti, i7 3770, ASRock Z77E, 16G RAM (8min) but when I rendered again..same AVI render I got a 5min 40second time..? Overclocking should get better times as seen below.
Blair Ryan
on Sep 14, 2012 at 4:54:37 pm
I have some very interesting results.
1. HP Elitebook
i5-2540M Dual core 2.60 GHz, 3 MB L3 cache
16gb 1333 Mhz Ram
Quadro 1000 2GB Ram
Time: 31 minute 14 seconds
2. i5 750 @2.67 GHz
8gb 1333 MHz
GTS 250 1GB
Time: 3 Hours 7 minutes
3.2. i5 750 @2.67 GHz
8gb 1333 MHz
GTX 580 1.5GB
Time: 5 minutes 33 seconds
Roy Foliente
on Sep 16, 2012 at 8:28:29 pm
Here are my results:
AE CS6 Version 11.0.1.12
i7 3960X OC 4.4GHz
64GB 1600MHz RAM
GTX 680 2GB (MSI Lightning OC 1176MHz) with driver ver 306.23 WHQL
Time: 6 minutes and 26 seconds
Philippe Kiener
on Sep 21, 2012 at 2:50:11 pm
Mac Pro 3.3 Ghz single processor, GTX 570 (for GPU) and GT120 (for GUI) from Macvidcards: 6min 30s
Andrei Chukin
on Sep 21, 2012 at 10:12:23 pm
Win & Mac... on the same hardware
3930K @4.2GHz
32Gb 1600MHz RAM
GTX680 Zotac (4Gb)
AE CS6
6min 28s
"HackPro5,1" 3.2GHz (Speed ​​Step is not working)))
6min 30s
Rainald Gervais
on Oct 7, 2012 at 11:32:18 pm
Windows 7 core i7-3930 CPU operating at 3.6 GHz
16 GB of ram
GTX 660 Ti (3 GB VRAM) overclocked = 1 min 3 sec to render
Andrei Chukin
on Oct 14, 2012 at 6:34:20 pm
Rainald Gervais
This benchmarking for Ray-traced 3D... not the Classic 3D renderer)
Craig Rogers
on Oct 16, 2012 at 9:25:19 pm
My results:
dual E5-2650
32GB RAM
GTX 690
4m 33sec
Alexander Rivera
on Oct 20, 2012 at 1:28:48 am
Here is my benchie:
Intel I7 3930K (OC) 4.7ghz
24mb of ram
Dual GTX 580 1.5Gb Mem (SLI): (OC) 822Mhz GPU 2050Mhz Mem
SLI Disabled:
Total Time Elapsed: 3 Min, 17 Sec
SLI Enable:
Total Time Elapsed: 3 Min, 15 Sec
So no benefit to use SLI or GTX590 for CS6. If the did support SLI properly 8-) wowser! I don't know if resolve does.
Arthur Velly
on Oct 22, 2012 at 6:33:32 am
4.29 min
GTX690
Robinson Sampaio
on Oct 22, 2012 at 9:32:52 am
Here are the results with the Adobe officially supported cards on a Mac:
GTX 285 - 28:47
Quadro 4000 - 18:04
A kind of joke lol... =P
Please, can you guys explain me how are you giving results with GTX 480/680/690 cards on a mac?
I need some references, because I'm definitely changing my cards!
antonio alucema
on Nov 7, 2012 at 7:09:51 pm
I just upgraded my 64-bit windows 7 workstation from a Quadro FX 580 to a GTX 680 and im having some serious anti-aliasing issues in After Effects with things such as Trapcode MIR, and Element 3D... everything seems really jagged and almost no anti-aliasing at all. I've updated to CS6 11.0.1 and tried to change the 680's anti-aliasing settings but nothing seems to fix the issue... anyone else had this problem? any ideas?
James Osbun
on Jan 29, 2013 at 12:42:36 am
HACKINTOSH - 4:25
2 x 2.5 GHz 6 core Xeons
48GB DDR3
2 x GTX 480 1.5GB
Lion 10.7.5
*Primary uses are: editing, color correction, and motion graphics
James Osbun
on Jan 29, 2013 at 2:18:12 am
Producer, Vice President (Monarex)
Film with Sony F3, Canon XF300 & 5D MKii (Zeiss glass, by Duclos)
Finish with 3 Hackintosh Edit Bays (by Cy)
James Osbun
on Nov 17, 2013 at 2:57:10 am
New result with dual GTX 580s 3GB RAM each.
2 min 52 sec
Raul Busquets
on Nov 9, 2012 at 2:17:46 pm
OS Mountain Lion
Mac Pro 3,1 2x3GHz Quad Core 24 GB RAM
GTX 660 Ti 3 GB
3 Minutes 54 Sec.
Kevin Snyder
on Nov 14, 2012 at 6:01:40 pm
i5 750 @3.6 GHz
16gb 1600 MHz
GTX 460 1 GB
Time: 13 minutes 24 seconds
alex tolo
on Nov 17, 2012 at 3:01:27 pm
Win 7 64Bit
Intel i7 2600 @ 3,4GHz
16Gb Ram
Zotac GTX 590 SLI (2x1,5 GB Ram)
4 Min 50 Sec
Jed Smith
on Nov 30, 2012 at 7:15:21 am
i7 3770k
32gb ddr 1600 ram
Nvidia GTX 670 2gb
Result: 6 min 43 seconds.
alex tolo
on Nov 30, 2012 at 1:24:01 pm
Okay finally my new GTX 680 4GB Phantom arrived and i did the same test again.
Win 7 64Bit
16Gb Ram
GTX 680 4GB Phantom
2 Min 49 Sec.
2 Min faster than with the Zotak GTX 590 SLI (2x 1,5GB)
But my VRam was not used much:
Thanos Kagkalos
on Feb 6, 2013 at 8:40:18 pm
How is that possible i do 7:07 on i7 3930k @ 3.5 / 32 gb ram / GTX 680 phantom 4gb / ssd intel 330
Isnt that a bit slow? i also noticed when i was working 3ds max my gpu based rendering was like 1 minute less than what i was reading in forums... What i ve possibly done wrong here? thanx
Teddy Gage
on Apr 21, 2013 at 7:59:59 pm
I find that render time extremely hard to believe from a 6xx series card, unless it is watercooled. Make sure your cache was cleared (if the frame are already on disc it will be 10x faster)
If confirmed, I will add it to the spreadsheet thanks
Daniel Witlox
on Dec 7, 2012 at 2:09:40 am
i7 860@2.80GHz
Windows 7 64 GB
6 GB RAM
MSI GeForce GTX 660
Render time: 10m 39s
Tom Daigon
on Dec 10, 2012 at 10:21:03 pm
GTX 570 HP Z820 1.25GB 480 cores 6:50 Render Time $315
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
evan fotis
on Dec 25, 2012 at 11:53:49 am
Got a lame 16m, 21s...
Win7x64, i7 350, 24GB Ram, Gigabyte GTX 460 1Gb used, rendered to a 2x1TB Raid 0 drive.
Time to upgrate GPU...
Which card would you suggest around $300?
Found the EVGA 660 Ti 3GB but read it does not support 4 monitors.
(Currently I have 2 cards installed to get 4 displays, but since both PS and AE performance is downgraded with dual cards I would prefer a single one that supports 4 displays)
ali demirtaş
on Jan 12, 2013 at 10:05:28 pm
GTX 580 3GB x 2_950mhz gpu 4600mhz ram oc
first time start, empty disk cache&clean database = 3m,5sn
Matt Buckley
on Jan 15, 2013 at 10:19:44 pm
Perfect time to find this thread. I have two video cards on hand and tried them both.
Common:
AMD Phenom II X4 965 Black Edition OC'd to 3.9ghz
8GB DDR3 RAM
Windows 8 64-bit
First video card:
GeForce GTX 560 Ti (Fermi) 2GB 256-bit GDDR5
core clock 880MHz
384 CUDA cores
AVI render time: 9 min 55 sec
Second video card:
GeForce GTX 650 Ti 2GB 128-bit GDDR5
core clock 1071MHz
768 CUDA cores
AVI render time: 4 min 14 sec
Interesting find. Across the board with game performance, the 256-bit memory in the GTX 560 Ti sports a noticeable performance improvement over the GTX 650 Ti with only 128-bit memory. But when it came to rendering this project (as AVI), the newer card was twice as fast. Maybe it does have a lot to do with the CUDA cores in this case.
ali demirtaş
on Jan 16, 2013 at 5:24:03 am
zotac 660 Ti AE 11.02 7m 50sn
Paulo Jose Papa
on Jan 25, 2013 at 2:10:40 am
Hi All,
Will there be a significant difference between GTX 660 TI and GTX 680?
Win 7 Ultimate
I7 3770k
16GB CL9
Vertex 4
Asrock Z77 Extreme 4
A reply would really be appreciated. I'm just a newbie in Adobe CS. thanks!
Peter Vartovnik
on Feb 5, 2013 at 7:15:34 pm
HP EliteBook 8560w
Win7 Pro (64bit)
i7-2670QM CPU @ 2.20GHz
16GB RAM
NVIDIA Quadro 2000M
32min, 5sec
Huggo
Eddie Pratt
on Feb 16, 2013 at 11:48:41 pm
5 mins 48 seconds
Mac Pro 4,1 Early 2009 - Dual 2.26GHz
24GB RAM
Lion 10.8.2
Single GTX 570 2.5GB VRAM - GPU 895MHz overclocked - Point of View (POV) TNT
In general I'm finding the performance of my machine on After Effects 6 better with just 1 graphics card (GTX 570) rather than adding the GT120 to use as a GUI card. This configuration works fine in Davinci Resolve lite too.
Outside this benchmark I've also noticed that the GPU is not used in lots of different situations whilst the CPU is heavily loaded i.e. when not using the Ray-traced 3D renderer. It seems like there must be a more efficient way of offloading CPU onto GPU when it's sitting there idly with practically no usage while the CPU struggles on!
Cheers,
Eddie
Michael Stephens
on Mar 11, 2013 at 9:22:19 pm
System specs:
AMD Phenom X4 9750
8G PC2-6400 (400Mhz) (5-5-5-18)
Windows 7 64-bit Professional SP1
GeForce 560 Ti: 11 minutes & 27 seconds
GeForce GTX Titan: 4 minutes & 33 seconds.
MOBO only has a PCI-E 1.1 slot so performance should be even better on a PCI-E 2 and 3 slot.
Michael Stephens
on Feb 20, 2015 at 6:24:31 am
New rig. New results.
System specs:
Intel i7-5820K (6 core) 3.30Ghz
32G DDR4-2400 (15-15-15-35)
GeForce GTX Titan
Render time: 3 minutes and 21 seconds
This shaves 1 minute and 12 seconds off my old rig with the same video card.
Ian Mapleson
on Feb 20, 2015 at 11:51:42 am
Very interesting! Thanks for the info! What was your old rig? Is there a post in this
thread somewhere? I'll have to search...
Ian.
SGI Guru
Michael Stephens
on Feb 20, 2015 at 3:02:40 pm
Original post is here, https://forums.creativecow.net/readpost/2/1033809.
I can set the PCI-E version in my BIOS so tonight I'll do another render test with PCI-E 1 and 2 and post a second set of results for both.
Michael Stephens
on Feb 21, 2015 at 2:20:28 am
Never mind about changing the bus version. I looked and it's not possible on the PCI-E x16 slot, just the other slots but that would mean I wouldn't get the full performance of the card if I moved it.
Matt DeLoach
on Apr 3, 2013 at 2:48:53 pm
PC w/ Windows8:
[ 8mins 36secs ]
Core i7 920 CPU (@ 3.9ghz OC)
12GB DDR 1600 Ram
GTX 470 (1GB ram)
iMac (late 2012) - OSX 10.8.3 Mountain Lion
[ 11min 2Secs ]
Core i5 3.2Ghz
16GB DDR 1600 Ram
GTX 675MX (1GB ram)
MacBook Pro Retina (mid 2012) - OSX 10.8.3 Mountain Lion
[ 29min 49Secs ] - Ouch. I spent 2Grand on the thing!
Core i7 2.3Ghz
8GB DDR 1600 Ram
GTX 650M (1GB ram)
Looks like I will be updating my home PC soon thanks to this thread!
Roberto Tafuro
on Apr 13, 2013 at 10:50:07 am
Intel i7 980x
GTX Asus 680 4GB
12 GB ram
First try 7min
Second try 18 sec...
Just to say that there are a lot of things that makes a render faster.
If you run a ram preview for ex it takes on my machine 4 minutes and the rendering takes 18 seconds after the ram preview.
If you lock the preview with the Caps the rendering is made in 5 minutes the first time. If i disable the Nod32 the rendering is done in 4 minutes too...
Funny esxperiments :)
Cesar Siena
on May 11, 2013 at 8:14:31 pm
Hi, I wonder how did make your Ae CS6 recognize the GTX 675MX card. Could you explain your steps, please? I work on PC's win8 and latest versions of Ae 11.0.2 and NVIDIA driver, but nothing's happening. Ae isn't able to recognize it as a compatible video board. Could you give me some hint? Thank you!
Carlos Yus
on Apr 17, 2013 at 9:12:25 am
i7 2600k CPU
16 GB RAM
Palit Geforce GT 440 1GB ddr5
time 39,43 min
Carlos Yus
on Apr 17, 2013 at 6:54:52 pm
And I decide to buy a new one!!
i7 2600k CPU
16 GB RAM
Gigabit Geforce GTx 660 2GB ddr5
time 10,08 min
So good!
Kahuna Kahuna Kj
on Apr 21, 2013 at 3:36:11 pm
Just for the record:
Intel 3770K @ 4.7Ghz
GTX Titan @ 1000Mhz (boost to 1167Mhz)
32GB @ 2400Mhz
Time to render: 3m28s
With Titan at stock 837Mhz
Time to render: 3m51s
Regards
Teddy Gage
on Apr 21, 2013 at 7:29:46 pm
This is very interesting. Been very curious about the Titan's performance in AE
So basically, the titan seems to brute-force its way through to times that can compete (although not outlass) a speedy 580 setup, despite having less than optimal CUDA performance like the rest of the 6xx kepler series.
However it seems it may be software-limited performance, given that it's basically just a consumer version of the k20 used in the tesla.
What I'm curious about is viewport performance in maya, and whether it can outperform the radeon 7970...
Teddy Gage
on Apr 21, 2013 at 8:43:41 pm
Guys, I have posted a spreadsheet of these results for everyone in .pdf and .ods format in the benchmark folder.
Hope these results are informative and thanks to everyone who has posted their info so far. If I didn't include your results I only used one system per GPU unless the results were radically different (ie amd vs intel).
I would love to get more quadro and tesla results if possible to add to the list. Thanks!
Teddy Gage
on May 15, 2013 at 2:00:07 am
I just got a GTX Titan and wanted to post my numbers
intel 3930K @ 4.6 ghz, with Titan @ stock speed = 3:57
intel 3930K @ 4.6 ghz, with Titan OC @ 1110 mhz base clock = 3:40
I will be testing this against a 2x GTX 580 in SLI, but still waiting on my second card
right now
GTX 580 3GB I am getting 5 min 5 sec with GPU clock at 925 mhz, or 5:45 at stock speed. testbed is intel 3770k @ 4.7 ghz
Teddy Gage
on May 23, 2013 at 5:14:12 pm
Just because I was curious, with double-precision on, the benchmark renders slower. Just tried it. not by much, maybe 5-10%? Honestly I have no idea what double-precision is useful for. Anyone can fill me in?
I was also wondering whether it was possible to edit a preferences file allowing AE to use more available VRAM. I understand limiting cards with less memory, but I'm only getting 4.5 GB of usable VRAM with the titan in AE. Granted, that is a lot but it would be great to get another GB and I doubt the OS needs more than 500 mb of overhead.
Tijmen Kuipers
on May 23, 2013 at 6:11:02 pm
Processor Intel(R) Core(TM) i7 CPU 860 @ 2.80GHz
Memory (RAM) 32,0 GB
EVGA Nvidia GeForce GTX680 4GB DDR5 Classified (PCI-e)
Render time: 7min 16sec
Alex Barrios
on May 24, 2013 at 3:17:43 am
Components:
All stock no OC
Motherboard: ASUS Rampage 4
PS: Corsair 1200
CPU: intel 3960x
Ram: Corsair Dominator GT 32GB
HD: Corsair GT solid state 240GB
Graphic card: 2 EVGA GTX 590- with old driver 301.42WHQL
i will try and post results with new Nvidia 320.18 driver
Render time: 3min 57sec.
Alex Barrios
on May 24, 2013 at 3:50:40 am
render time- 3min 40sec
Adrian Thompson
on May 26, 2013 at 11:11:42 pm
Mac 4,1
8-core 2.26Ghz
32GB Ram
7200rpm hard drive
Latest version of Mountain Lion and Nvidia Drivers.
Nvidia GTX 570, 2.5GB (flashed by MacVidCards)
6 Min, 51 Sec
Herbert van der wegen
on May 30, 2013 at 8:18:57 pm
On my system (see sig below) I get 4min11s. Not too bad for a $300 second hand 590!
System: Win7 64bit - i7 920@3.6Ghz, p6t Deluxe v1, 48gb (6x8gb RipjawsX), ATI 7970 3gb, EVGA 590 3GB, Revodrive X2 240gb, e-mu 1820. Screens: 2 x Samsung s27a850ds 2560x1440, HP 1920x1200 in portrait mode
Nevin Styre
on Jun 7, 2013 at 6:19:33 am
4:43
Win 7
i7 920 @2.8GHz
16GB DDR3
GTX 780 3GB
Wish I had tested before I swapped out my 570.
Ian Mapleson
on Jun 11, 2013 at 9:53:49 pm
Using one to three GTX 580 1.5GB cards, all set to 800/2010/1600 core/RAM/shader
(these cards will run at over 900 no problem, but not on this mbd, there isn't
enough room for proper cooling):
3x 580/800: 2 mins 55 secs
2x 580/800: 3 mins 31 secs
1x 580/800: 5 mins 36 secs
System:
ASUS Maxiumus IV Extreme
i7 2700K @ 5.0GHz
Thermalright Venomous-X with 2x Coolermaster Blademaster fans
32GB DDR3/2133 CL9 (GSkill TridentX 2400 4x8GB kit)
1kW Thermaltake Toughpower PSU
CPU-Z: http://valid.canardpc.com/2829919
I'll test with 4x 580 later, using two other motherboards with different
CPUs: ASUS P9X79 WS + 3930K, and an ASUS P7P55 WS Supercomputer + i7 870.
I'll also be testing with one to four GTX 460s, and retesting with 3x 580
using a different board which will permit better cooling and thus the cores
increased to about 900 or so (Asrock X58 Extreme6 with a XEON X5570).
Ian.
SGI Guru
Teddy Gage
on Jun 11, 2013 at 10:27:40 pm
You're insane! Nice results on the 3x gtx 580, that's the fastest render recorded so far. but I'm surprised to see the gains offered by a third card are pretty modest. Although if it comes to rendering long projects it could be handy, I think 2x GTX 580 SLI is best price point to performance ratio.
Ian Mapleson
on Jun 12, 2013 at 12:49:09 am
Teddy Gage writes:
> You're insane! ...
In today's world I'll take that as a compliment. :D
These are the four cards I bought btw:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=151052818493
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130916895940
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=200925198261
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=171044128930
Total cost: 530.40 UKP. Reasonably good value I reckon; a little more
than half the cost of a Titan yet quite a bit quicker even with just
3 cards. Power consumption probably sucks of course (not checked yet),
but then that's the tradeoff between cheaper multi-old-used vs. fewer
expensive new. However, I only bought these for AE/CUDA research and
general 3D benchmarking, so power consumption doesn't really matter atm.
I also won a 3GB GTX 580 which I'll be sending to someone to upgrade
the AE system I built for them back in Feb (see this thread).
> ... Nice results on the 3x gtx 580, ...
Thanks!!
> ... that's the fastest render recorded so far. ...
It is? I'm surprised. Nobody here with two Titans? That ought to
beat three 580s. Speaking of multiple Titans, have a look at this:
http://www.randomcontrol.com/arionbench
Anyone know what kind of systems they're using which can hold that
many GPUs? Or are they using water cooling so as to only use single
slots? Either way, talk about OTT...
> ... but I'm surprised to see the gains offered by a third card
> are pretty modest. ...
Doesn't surprise me TBH, I've seen this effect before. Of course one
shouldn't expect it to be more than a 3rd better anyway, but just like
going from 2-way to 3-way SLI, the gains are often less due to the extra
overhead processing required. Indeed, for some types of render in AE
(those involving a lot of particles, or scenes that are not so optimally
constructed), it's possible for one GPU to render faster than 2+ GPUs
(bad GPU thrashing occurs).
Games show similar effects - unless the drivers have game-specific
optimisations, often 3-way SLI can be slower or more erratic than 2-way,
and even when 3-way does work ok if one then jumps to 4-way SLI the effect
can be abysmal. Experimenting with the different SLI rendering modes then
becomes necessary, which is a pain. At least rendering in AE doesn't need
SLI mode to be active. Similar effects plague the use of CF for games.
> ... Although if it comes to rendering long projects it could be handy, ...
That's true, on a long render the speedup will be significant; useful for
looming deadlines, etc. 8)
Since a system can't really be used while a render is in progress, I
reckon the optimal setup would be one system designed for strong
interactive performance (single Titan or whatever), plus a separate
system with as many powerful GPUs as possible, eg. Asrock X79 Extreme11
with seven water-cooled 1-slot 3GB 580s (or Titans) would be good, but
not cheap. :D
Of course that doesn't help CPU-limited tasks like Classic3D render.
Stepping up from a well oc'd 3930K is tricky; multi-socket is costly,
while a compatible 8-core XEON for a 1-socket board has a much lower
base clock and thus less oc potential (3930K is probably faster overall).
Hmm, anyone know of a good quad-socket board? I doubt those offer much
in the way of oc'ing functionality though.
> ... I think 2x GTX 580 SLI is best price point to performance ratio.
Note that SLI mode is not necessary for AE. I tested using two GTX 280s
using a different scene (takes about 5.5 mins), render time was only
0.004% different for SLI vs. no-SLI.
Ian.
SGI Guru
Maurizio Schmidt
on Jun 14, 2013 at 7:15:23 am
i7- 4770k
GTX 680 4GBRAM
Crucial SSD
Ian Mapleson
on Jun 14, 2013 at 2:01:39 pm
That doesn't sound right - 78s with a single 680?? An earlier
post gave more like 7 mins for one 680 card. 78s is like 2X
faster than a Titan.
Can you post more details of your system please? Perhaps a
screenshot from GPU Shark? Or a CPU-Z submission? If you're
somehow getting magic speed from a 680, I'm sure others would
love to know how.
Ian.
SGI Guru
Andrei Chukin
on Jun 14, 2013 at 2:29:50 pm
... obviously test was conducted through Classic 3D renderer instead of Ray-traced 3D
3930K @4.6GHz
32Gb @ 1866MHz RAM
GTX680......
48s :)
Ian Mapleson
on Jun 14, 2013 at 4:17:21 pm
Check the title of the thread - it's GPU accelerated results
that people are expecting to be posted here, ie. a CUDA test.
Classic3D uses the main CPU.
Ian.
SGI Guru
Andrei Chukin
on Jun 14, 2013 at 4:31:54 pm
sure!!! ... http://forums.creativecow.net/thread/2/1019120#1024833
Ian Mapleson
on Jun 15, 2013 at 10:48:35 am
You've already posted the GPU result? I think that just
highlights my point even more. :D Posting a Classic3D
time aswell is just going to confuse people. Kinda
meaningless too since it doesn't result in the same output.
Ian.
SGI Guru
Andrei Chukin
on Jun 15, 2013 at 11:01:11 am
... my post was just an illustration to explain such a "fantastic" result by Maurizio Schmidt on Jun 14, 2013 at 11:15:23 am http://forums.creativecow.net/thread/2/1019120#1038327
BTW http://forums.creativecow.net/thread/2/1019120#1025648 ... another "record".
Ian Mapleson
on Jun 15, 2013 at 11:03:40 am
My goof!! Brain not engaged - saw your gfx listed as a 680,
didn't realise you were a different poster. :D
Apologies...
Ian.
SGI Guru
Maurizio Schmidt
on Jun 17, 2013 at 8:00:01 am
to clarify my results:
raytraced:
classic3d:
is it normal that neither the CPU or the RAM is at its max and still its so slow ?
Andrei Chukin
on Jun 17, 2013 at 2:24:57 pm
You have uploaded the same screenshot (Ray-traced 3D) twice)))
Ian Mapleson
on Jun 17, 2013 at 2:27:15 pm
What do you mean slow? Instead of using Classic3D (which
does not produce a comparable result anyway), switch the
processing to CPU-only and see how long it takes - then
you'll see slow. :D
Remember this is supposed to be a GPU test. I don't see
the relevance of discussing Classic3D results.
NOTE: in time, it's likely your image links will no longer
work. I recommend including text in your post to summarise
the processing times. Don't rely on image inclusions.
Ian.
SGI Guru
Paul Roper
on Jun 17, 2013 at 4:51:14 pm
A rather sluggish 10:24 on my Mac Pro:
2x 3.06GHz 6-Core Intel Xeon
64GB 1333MHz DDR3 RAM
2x Nvidia Quadro 4000 (2GB RAM each).
It'll be interesting to see if After Effects CC makes any improvement.
- Paul
Ian Mapleson
on Jun 17, 2013 at 5:38:48 pm
Paul, don't worry, that's perfectly normal for a couple of Quadro 4000s.
Testing one Quadro 4000 with my 5GHz 2700K gave 17 mins 53 secs, but this
dropped to only 8 mins 35s with the addition of just one GTX 460. Quadro
cards are much faster than gamer cards for most pro apps (Ensight being
the exception) because of optimised drivers, etc., but they don't have
that many cores for CUDA.
Ian.
SGI Guru
Teddy Gage
on Jun 17, 2013 at 5:54:37 pm
Ian, Quadro cards are not faster than consumer gaming cards. In fact many are more or less the exact same hardware as much older gaming cards. I think these benchmarks, being a raw test of computing power, prove this.
What you are paying for in the quadro cards is:
- better drivers
- greater viewport accuracy
- better binned chips. ie. the quadros are tested much more rigorously for faults
- they typically run cooler, have smaller form factors and draw less power
- 24/7 customer support
but they are definitely not "faster".
IMO the GTX Titan is actually the sweet spot between CUDA performance, viewport accuracy, raw processing power and gaming performance. If you can find one, the GTX 580 is also a great deal. People believe they are faster because they have paid thousands of dollars for the quadro name.
Ian Mapleson
on Jun 17, 2013 at 6:27:59 pm
Teddy Gage writes:
> Ian, Quadro cards are not faster than consumer gaming cards. ...
Nope, that's wrong. Whether it's the hw or the drivers,
simple fact is performance for most pro apps is by far
and a way much quicker with a Quadro. Otherwise, care
to explain my Viewperf results?
http://sgidepot.co.uk/misc/viewperf.txt
Not necessarily much older, they just have a lot fewer
cores (deliberately so).
> - better drivers
Exactly, and optimised drivers too, which leads to
better performance for pro apps, because games use functions
which pro apps don't need at all, and vice versa. The sw
optimisations are criticial. For similar reasons, Quadro
cards are terrible for gaming.
My results prove otherwise. I've seen this argument rage
so much on different forums, but the numbers don't lie.
Titan is dreadfully overpriced and deliberately crippled,
just like the 780. Both cards could easily be massively
faster than they are, if given a quicker mem bus (512bit),
but NVIDIA won't do that because they know it would eat into
Tesla sales.
> ... If you can find one, the GTX 580 is also a great deal.
See my earlier post, I have four. :D
> ... People believe they are faster because they have
:D
One of my Quadro 600s only cost me 25 UKP. It's 50% faster
than a GTX 580 for Catia/Lightwave, about the same for Maya,
more than 2X faster for SW, 4X faster for SNX, 5X faster for
ProE (which is CPU-bound anyway), and 14X faster for TCVis.
A quadro 4K leaves the 580 in the dust.
Ensight is the exception. Gamer cards do well for this in
raw performance terms.
Ian.
SGI Guru
Teddy Gage
on Jun 17, 2013 at 9:20:18 pm
AE being, of course, another exception.
I did some research of my own, and I don't usually say this, but I think you are right. Although it really depends on a) what your definition of "faster" is and b) what you're using the card for. I wasn't aware of the massive difference in viewport performance for maya etc. Now whether that built into the drivers or is a factor of unlocked hardware is hard to tell. I would favor an answer in software. But I would disagree about the Titan being overpriced. It is really an amazing card. Especially once you've seen what it can do on multi-monitor 2k openGL performance, while running cool, not requiring SLI, having 6GB RAM and using fewer watts. Add to this the ability to enable double precision floating point calculation. I honestly believe GPU rendering is the future, and this card can compete and outperform a $3000 "pro" equivalent on that front, so I think it is a great value. Just maybe not to your average gamer who just wants to run the latest call of duty.
Ian Mapleson
on Jun 17, 2013 at 10:45:34 pm
Teddy Gage writes:
I assume you mean from a performance perspective, yes; presumably such users would
still benefit from the other differences you mentioned.
> ... Although it really depends on a) what your definition of "faster" is ...
The results are pretty clear for the Viewperf tests.
However, Viewperf can indeed be misleading and should be used with care. For
example, those tests do not take into account situations where some kind of
host processing is required which is unrelated to the 3D rendering pipeline
in any direct sense. I recall an oil rig database which, for every frame in a real
time vis sim, the database info had to be converted into Performer for rendering.
This required a lot of preprocessing (8 CPUs working together). Likewise, as I'm
sure you know, AE can gobble huge amounts of RAM, whereas Viewperf 11.0 only needs
8GB to run ok.
But as a basic 3D comparison in those apps where RAM/CPU is less critical, the
differences can be enormous. The ProE, TCVis and SNX results are particularly stark.
> ... I wasn't aware of the massive difference in viewport performance for maya etc. ...
Maya seems to be an inbetween case. I've not checked for a while, but I bet the
situation I found many years ago is still the case, ie. if one examines the individual
test results that make up the SPEC Maya suite, gamer cards will be good at some things,
but bad at others, the combination of which evens out the final average. Alas it's still
not enough for a gamer card to outpace a Quadro, just look at how a GTX 580 compares
against a Quadro 4000.
What I was told long ago is that the Quadro drivers provide strength for functions such
as antialiased lines (not needed in games), while gamer drivers are strong for other
things such as 2-sided textures (generally not used in pro apps). Lots of new features
since then, but I expect similar things still apply.
> hard to tell. I would favor an answer in software. ...
Probably both.
It's fast, but it's not sufficiently faster than a 780 to warrant the price
difference IMO, and the 64bit fp lockout on the 780 is deliberate (I view this
as the 780 not having something it should have, rather than Titan having something
it normally wouldn't). Likewise, the use of a narrow bus in all these recent cards
means the cores cannot be fed fast enough to fully exploit them, hence the bizarre
differences in CUDA performance vs. a 580 which has massively fewer cores:
http://www.tomshardware.com/reviews/geforce-gtx-780-performance-review,3516...
Or to put it another way, with respect to AE, how is it possible for two 580s to
be so much quicker for your test than a single Titan? It's all about the mem bw.
NVIDIA could have made Titan a massively quicker card by using a wider bus, but
as I say that would harm Tesla/Quadro sales. My own results are quickly leading me to
the conclusion that overall accelerated GPU performance in AE is all about balanced
aggregate bandwidth per CUDA core, though it's also scene-dependent.
> ... Especially once you've seen what it can do on multi-monitor 2k openGL performance, ...
On that front you're absolutely right. :D
In the same way though, why is there no 6GB 780? As a gamer card it's often little
slower than a Titan, eg.:
Likewise, why does the 770 only have 2GB RAM? (though there's a Gigabyte with 4GB)
NVIDIA is being very careful how it positions these products, so it won't harm its
pro card sales too much. It's akin to Intel making the 2500K far too good for oc'ing
(took me less than 3 minutes to get mine to 4.8GHz stable); those with that chip see
no reason to upgrade, so Intel used a garbage TIM with IB so it would run a lot hotter
(replace the TIM and temps can drop by up to 30C). If NVIDIA released a card like the
780 with a 512bit bus (etc.), it would be a price/performance CUDA killer, in which
case bye bye lots of Tesla/Quadro sales. The only things that hold this back in other
areas are ECC RAM and issues such as the restricted GPU to host return path in gamer
cards for CUDA.
I know someone who does a lot of CUDA programming for financial transaction processing;
he's explained many of these issues to me in recent months.
> ... Add to this the ability to enable double precision floating point calculation. ...
Indeed, but I guess my viewpoint tends to approach this from the other direction; most
will regard it as 'good' that the Titan has this feature, and I agree, but my immediate
reaction is it's bad that other cards don't have it when clearly they could have,
ie. the lockout is deliberate. The potential is there, but not permitted.
> a $3000 "pro" equivalent on that front, so I think it is a great value. ...
Definitely agree there, when it comes to GPU acceleration these cards are great, though
it's a pity NVIDIA ignores other aspects of the design which mean their cards continue to
badly trail AMD in some areas, and again show the strength of the older 580:
Imagine if NVIDIA simply activated the 64bit 1/3rd option on the 770/780. But they won't.
As it happens though you're actually right again there, because the Titan's big
RAM means in many cases it's a better option for multi-screen gaming at high
resolutions, ie. the scaling with Titan SLI works far better than two 690s or
multiple 7970s, etc. If one could get a 780 with 6GB RAM though, that would be
more sensible than Titan given its enormously lower price.
What AMD doesn't have is a product akin to Tesla. I guess as long as that's the case,
NVIDIA has no need to produce a version of GK110 that really is as good as it can be,
ie. consumer-type RAM setup with restricted return path, but full 64bit activation
and a wide memory bus to fully feed all its cores. Such a card would blow everything
else away for CUDA (it would be at least 2X faster for AE than the current Titan),
but such a card would also be too good - NVIDIA just doesn't need to produce
something like this yet, it'd eat too much into Tesla/Quadro sales.
Personally I think it's sad that SGI's old ethos of gfx product design is gone. Think
back to the days of MaxIMPACT; it was seriously expensive, but when it launched it was
10X faster than anything else available, so it sold like hotcakes because the price
was well worthwhile. Ditto for IR. Their philosophy in those days was, what can we make
with a budget of $10K? Or $50K? Imagine that now: what could NVIDIA build if other
factors (such as harming other areas of their own product range) didn't matter? How much
would you be willing to pay for such a thing? Imagine Titan with a 1024bit bus, even
more RAM, full 64bit activation and no restricted return path - it'd cost more, but not
that much more, though they could price it way higher no problem.
Alas it won't happen. Not unless AMD does something unexpected in the pro space which
suddenly pushes available OpenCL performance massively ahead.
Ian.
SGI Guru
Várbjørnin Í Kavanum
on Jun 24, 2013 at 3:31:54 pm
Hey guys. Me and my partner are planning to invest in a new computer for video editing, mostly used for AE, Premiere and also Resolve. We would like to know what you think of our planned system and its components, suggestions, and what you would change/rather use. We are a little unsure of some of the components, mostly the gfx's, which we would hope you could help us out with.
First the system
GFX - 1x EVGA GeForce GTX Titan - 6GB
RAM - Kingston 64GB DDR3 1600MHz (8x8)HyperX
HDD - 2x Intel 520 SSD Series - 240GB
ROM - 1x Lite-On iHBS312 - BR-R & DVD±RW - Black
CPU - 1x Intel Core i7-3930K Sandy Bridge-E
CPU Cooler - Phanteks PH-TC14CS CPU Cooler - Blue
STORAGE - Western Digital WD Green - 3TB 2x
MOBO - ASUS Rampage IV Extreme
PSU - Corsair AX1200i - 1200W PSU
What we are most unsure of, is the gfx choice. Is our Titan choice the best card for pure performance for AE, premiere and resolve?
How does the 690GTX fare against the TITAN? And finally how do the Quadros 4000-6000 compare to the two mentioned geforces?
Thanks for your kind help guys. Much appriciated.
Polar Films Entertainment
Ian Mapleson
on Jun 24, 2013 at 6:49:05 pm
Várbjørnin writes:
What case are you going to use for this build? I recommend something
sizeable with plenty of potential airflow. I used the Coolermaster HAF
932, with the PSU positioned at the top of the case to permit 4 GPUs to
be installed.
Hmm, not what I would choose. GSkill would be better IMO. I've never had
good experiences with Kingston RAM (all too often I found they just would
not run at their rated speed, whereas GSkill and Mushkin had no problems).
Also, given memory bandwidth is useful for AE, two kits capable of 1866
or 2133 would be preferable. I decided to ensure extra stability by getting
kits rated at 2400 so that I could set them at 2133 without worry, though
ironically at the time the 2400 kits were cheaper than 2133 kits.
Make sure you get the C2 stepping. I think the relevant SPEC code is SR0KY.
Are you going to oc the CPU? If so, then get the Phanteks PH-TC14PE instead.
Eek! No! Such disks are not designed for professional use, and buying
disks aimed at power saving fanatics is a bit pointless when you're
building a 6-core system with 64GB RAM and a Titan. :D You're just
asking for a disk failure with disks like the Green. At the very least,
get WD Black instead, or the Seagate models that end with NS (more
reliable than consumer AS). I went a step further and managed to obtain
some 2TB Enterprise SATA drives.
That's really a board designed for gamers; its features reflect this.
For long term investment in an AE setup, I would have thought the newer
version of the board I'm using is better, namely the ASUS P9X79 WS-E
(mine is the older ASUS P9X79 WS). See:
http://www.tomshardware.co.uk/ASUS-LGA2011-X79-P9X79-E-WS,news-44472.html
Compare the WS-E to the Rampage:
https://www.asus.com/Motherboards/P9X79E_WS/#specifications
https://www.asus.com/Motherboards/RAMPAGE_IV_EXTREME/#specifications
The WS-E has a better and more flexible PCIe configuration, and it has
more 6Gbit SATA ports. It also supports XEONs, though that would only be
relevant if Intel bothers to release an 8-core IvyBridge-E at a decent
clock speed later this year (unknown atm); point being, Rampage boards
don't support XEONs.
Both boards have the same overclocking features. The WS-E costs more,
though even the older WS would be more appropriate than a Rampage IMO.
I spent many days examining a wide range of boards for use with AE,
including the Asrock X79 Extreme11 (because it has onboard SAS), but
in the end I felt the WS was the best choice; today it'd be the WS-E.
That should be ok to begin with. Do you think you'll ever expand the
system to have four gfx cards for max CUDA performance? 1200W is probably
ok for 2 or 3, but I'd want something a bit better to handle 4, especially
if you plan to oc the CPU.
Looking around, I see that the PSU I bought recently is pretty much the
same price as that Corsair, so why not get a 1475W Thermaltake Toughpower
XT Gold instead? Then you'd have plenty of headroom for the future. See:
http://uk.thermaltake.com/products-model.aspx?id=C_00001812
Certainly though, to begin with, any PSU at this level will be just fine
for a 3930K and just one GPU. Best to plan ahead though.
(note that I can't comment on Premiere and Resolve, I'll leave that to
others, but with respect to AE...)
That depends on your performance priorities. For a single card, it'll
certainly give the best performance for any task that only uses the
primary GPU (perhaps others can comment on how this relates to using
Premiere/Resolve because that's beyond my knowledge, I've only been
researching AE), and it means the maximum unused slots for future
expansion. On the other hand, two older GTX 580s would cost less but be
faster for any task that can use multiple GPUs, such as CUDA rendering (a
single Titan would use less power, but take longer to complete a task).
One thing though, Titan does have the option of operating in 64bit mode
for which 1/3rd of the cores are available. By contrast, all the other
cards (including the 780) only provide 1/24th of the cores for 64bit.
I'm not sure yet how this difference might translate into better workflow
or rendering with AE, but certainly for the benchmark discussed on this
page it doesn't seem to help, assuming of course that those with Titans
who have posted here have checked to see if there's a difference between
standard and 64bit mode for running the test. Alas I don't have a Titan
yet for my testing, so I can't say.
Mind you, how realistic is the test used here? It's really the same
general image rendered multiple times. I'm working with someone on a more
complex & varied test, based on real commercial work. The goal is to have
a test suite that consists of a single-frame render (typical for when one
is creating a large billboard poster advert, for example) and then an
animation render test, which tomshardware will use in their CUDA review
tests. Someone for whom I built an AE system is designed the tests, might
be ready this week or next perhaps.
> How does the 690GTX fare against the TITAN? ...
Similar issues when comparing against two 580s or a 590, though note the
580 is _faster_ than the 680 for CUDA (the 600 series suffers from
inferior memory bandwidth issues). Indeed, the 580 beats many of the 700
series cards in a lot of CUDA tests.
In the past, AE had difficulties exploiting both GPUs on a dual-GPU
card. Not sure if this is still the case. Have a look at the results
here, see if those posting 590/690 results show any relevant speedup
compared to a single 580/680.
> ... And finally how do the
Quadro cards offer better display port performance, but it seems likely
this is less relevant for AE given the way many functions are GPU
accelerated (don't know about Premiere/Resolve). However, Quadro cards
have far lower CUDA performance as they have fewer cores, so a Quadro
would not be as good as a Titan for GPU accelerated rendering. Other
differences include driver optimisations, reliability, warranty level,
etc., plus & minus things on both sides - see Teddy's recent post for a
summary, and my followups.
Absolutely without question though, if you only want to get one card to
begin with, then don't get a Quadro as it'll be nothing like as good as a
Titan, 2x580, etc. for GPU-accelerated functions.
Overall, if you do want to go for max CUDA performance while minimising
initial cost (at the expense of power consumption), then multiple GTX
580s are definitely best (find 3GB editions if you can). 1.5GB cards are
going pretty cheap on eBay - for less than the cost of a Titan, you could
get four 1.5GB cards, but this means initially more limited VRAM (mind
you, the faster performance means you could get tasks done quicker,
perhaps help to bring in money faster, upgrade to multiple Titans sooner;
just a thought). Alternatively, and even better, get a Titan as the
primary card (buy it new), and add two 2nd-hand 3GB GTX 580s for extra
CUDA oomph, when you can find them. You can always replace the 580s later
with more Titans.
Ian.
SGI Guru
on Jun 25, 2013 at 2:17:38 pm
Thanks for the quick reply! And a good one it was! Really helpful. Will be coming back to this site in the future for sure.
Again thanks!
Ian Mapleson
on Jun 25, 2013 at 6:07:00 pm
Most welcome! Do hunt around for other opinions though since
I don't know how much of what I said would apply to Premiere
and Resolve.
Ian.
SGI Guru
Teddy Gage
on Jun 25, 2013 at 7:12:25 pm
The Titan is fantastic for Resolve and Premiere pro. Extra video memory and they can use all CUDA cores. Not sure about ability to use both cards on 590 or 690. Plus less heat and power generated. A Quadro is really only necessary for 3D apps that need viewport accuracy and performance, or if you need a 10bit monitor support / SDI output.
I highly recommend the Asus boards that Ian mentioned. As well as a better cooler. I'd recommend the corsair h80 or h100. That chip was meant to be overclocked. It is very easy, even for beginners.
Ian Mapleson
on Jun 25, 2013 at 7:42:50 pm
Thanks for the extra info Teddy! Yup, the H100 (or newer H100i)
is good, assuming one has an appropriate case. Not sure about
the H80, that might be tad too far down the scale.
Várbjørnin, if you do use a water cooling kit such as an H100,
remember to ensure that extra dedicated cooling is somehow
directed at the mbd chipset areas, since normally an air
cooler naturally tends to blow some air over these parts; see
my earlier posts for examples of how this can be done with an
air cooler like the large Phanteks PH-TC14PE.
Teddy's right about oc'ing btw, it really is just free
performance waiting to be exploited. At the very least, you
could work out a suitable overclock which does not require any
extra core voltage (and thus no change to power/cost ratios).
Ian.
SGI Guru
chow jee peng
on Jun 28, 2013 at 10:44:42 am
Mac OSX 10.7.5
AE CS6
2 X 2.4 GHz Quad-Core Intel Xeon
32GB 1066 MHz RAM
NVIDIA Quadro 4000 2048MB
Time: 18 minutes
Ian Mapleson
on Jun 28, 2013 at 4:00:07 pm
That correlates nicely with my own testing; a Quadro 4000 on
a P67 board with 5GHz 2700K gave 17 mins 53 secs.
Ian.
SGI Guru
Greg Antons
on Jul 18, 2013 at 10:13:43 pm
i7 860 @2.9ghz
16gb RAM
GTX 570 1.2gb, 480 cuda
6min 3sec to render
its interesting to see that some of the x80 cards arent performing as well as my 570. Anyone know why?
Ian Mapleson
on Jul 18, 2013 at 10:58:03 pm
It's all to do with aggregate bandwidth per CUDA core and
other differences. See:
http://www.tomshardware.com/reviews/geforce-gtx-760-review-gk104,3542-19.ht...
A 770 or 780 has lots of cores, but they don't have
correspondingly higher bandwidth to feed them all.
Ian.
PS. Edit: I've been told by C. Angelini @ toms that the
shaders in the 580 run at twice the clock rate of the
later shaders used in 600/700 series cards, so that's
another major factor for the strength of the 580. He
said NVIDIA switched to having a larger number of lower
clocked shaders because that made thermal issues easier
to deal with, but of course it means a newer card must
have a lot more shaders to beat a 580, which some do,
but then they don't have the mem bw per core to match.
Must be a combination of these factors I suppose.
SGI Guru
Andrei Chukin
on Jul 30, 2013 at 2:51:02 pm
3930K @ 4666MHz
32Gb @ 1935MHz RAM
GTX680 Zotac (4Gb)OC'd
5min 58s
John Hsu
on Aug 13, 2013 at 8:32:05 pm
I ran this benchmark and got 6:30 min with multiprocessing on, but when I turned MP off it rendered in 3 sec, anybody know what's going on?
Adobe After Effects CS6 (v11.0.0.378)
Intel i7-3770
3.4GHz
NVIDIA GeForce GTX 570
4 core (8 virtual)
16 GB RAM
Windows 7
Teddy Gage
on Aug 13, 2013 at 8:47:13 pm
You didn't clear the cache between renders, so it was just spitting out the previously cached frames. hence the 1 sec render. You'll have to clear the disk cache and RAM to get a new test.
however MP is irrelevant for this test, as it is turned off when artisan (the raytraced renderer) is used. Those results are in line with your gpu
John Hsu
on Aug 13, 2013 at 9:10:42 pm
That's great, thanks for the quick reply!
Paul Forcier
on Sep 4, 2013 at 11:56:58 pm
Thanks for starting this thread I have been very curious about cuda performance.
I got 4 min and 3 sec
EVGA SR-2 Xeon X2 at 2.4 OC to 3.4 with H80 water-cooling
48 Gig ram
480 SSD Boot drive with a 3-way Raid for writing files 600 gig each Velociraptors
2 256 gig ssd raid for a performance cache on a Apricorn Solo X2
1 128 GB for source files (have to do something with that)
1 128 Gb older cache drive
4 TB USB 3 drive for offloading data
GTX 690 Primary driving a 30" Dell
GTX 670 Secondary driving two 20" Dells for a PLP setup
Both cards have the same cuda compute level so they appear to both be recognized by AE CS6
Ian Mapleson
on Sep 5, 2013 at 9:56:31 am
I'm intrigued by your mbd/CPU setup; what model XEONs do you
have on the board? How did you find the experience of oc'ing
them compared to normal boards? Any issues specific to working
with two XEONs? Also, is the RAM ECC, and at what speed is it
running? Nothing to do with CUDA of course, but your system is
similar to something I've been discussing with a friend.
Ian.
SGI Guru
Paul Forcier
on Sep 5, 2013 at 10:01:31 pm
Hi Ian, I'm using the Xeon e5645's which were less expensive and easily overclocked, unlike the current generation of Xeon which are locked out in that regard.
After the seven stages of grief over the EOL of Final Cut Pro 7 I moved back to a PC from my 1st Gen Mac Pro...to the CS6 suite - I originally was on Premiere Pro before going to Mac several years ago so it wasn't completely unfamiliar to me.
Anyhoo I did a great deal of research and found the enthusiast EVGA SR-2 board and investigated the overclock capabilities as well as those Xeon chips. Many have had great success overclocking to over 4 Ghz with even better chips of that generation like the 5690, though they were a great deal more expensive.
My system has been very stable with this OC and have had no issues. This effectively has given me 12 Cores at 3.4 Ghz easily and 24 threads with multi-threading.
I am using Kingston non ecc ram 12 X 4 GB for 48 total or 4 gb per CPU core. They are 1600s. I'd have to check to see how fast I have them running with the OC.
There are i7s out there with 6 cores that will provide a higher benchmark on the benchmark test, with a high OC well over 4 ghz,...my 12 core gives me great performance running multiple applications spread across the PLP setup.
I am considering adding another GTX 690 for SLI with some games for my kids (ok, maybe me too, such as Battlefield 3 which responds well with 4 way SLI on the two 690s) and add more cuda at the same compute level for After Effects CS6 in relation to the ray tracing....If I do this I will run the benchmark again and report in....
The short lived EVGA SR-X replaced the SR-2 but, no fault of EVGA, the compatible Xeons could no longer be overclocked. The performance difference in my eyes led me to the older SR-2 which can still be found out there...
Regards - P
Ian Mapleson
on Sep 6, 2013 at 1:28:00 pm
Paul Forcier writes:
> in that regard.
Indeed! The pice looks quite good for a 6-core 2.4 X58. Wouldn't make
sense for a single-socket system of course, but for a dual-socket setup
that's a nice compromise.
Yeah, exponentially explodes cost-wise above a certain point. That's why
I initially bought a used X5570 4-core (by default it'll run at 3.2)
which only cost me 200 UKP at the time. It was cheaper than an i7 950,
has 50% faster QPI and a higher TDP, so in theory should oc easier,
though at least on my board (Asrock X58 Extreme6) this has proven a
challenge with the board maxed out to 24GB. I did manage to get a crazy
cheapo i7 990X much later but I've not installed it yet, still testing
the X5570 setup.
> multi-threading.
That should run really well, akin to a top-end Dell T7500 with 2 of the
best 6-cores. What do you get for CB 11.5?
I've read about issues trying to oc X58 boards when all the RAM slots
are populated. Be interesting to know what you ended up with.
I'm not so sure about that. :D Yes, the 990X, 3930K, etc. can reach
4.7/5.0 respectively with a good setup, but I suspect your decent clocks
and 12 cores will mean your setup actually has a useful advantage. Not a
huge amount better, but definitely better. I'd be surprised if your CB
11.5 score was less than about 16 or 17. I'll make a guess and say it'd
be about 16.5, 17 at best.
> way SLI on the two 690s) ...
You'll need extra tissues to cope with all the drooling. :D
Should be interesting!!
> out there...
Yes, that was the conclusion I came to when talking to my friend. For an
oc'd dual-XEON setup, older X58-based boards make more sense.
Thanks for the info!!
Ian.
SGI Guru
Teddy Gage
on Sep 6, 2013 at 5:15:38 pm
I still think two 3930K machines are preferable to a single dual-cpu xeon setup. No matter how many cores you throw into one machine, it will still be tied up during render time. I have two master workstations in a dual-dvi KVM switch setup, and there's always one rendering and one working. and if I need both rendering I have a networked 8TB NAS. One machine has a GTX titan, the other has a dual GTX 580 SLI setup for heavy CUDA and transcoding. That machine also has two SSDs in RAID 0 maxing out sata 6 bandwidth (500+ MBps IO) for disk-intensive fluid simulation etc. Not to mention it's much more affordable, and a setup that's easier to troubleshoot and fix (along with system backups of each machine). I get around 13.5 CB score on the 3930K @ 4.8 gHZ
Ian Mapleson
on Sep 6, 2013 at 5:46:09 pm
I guess it depends on what one is doing. Lots of cores in
one system will obviously be better for Classic3D mode,
or for rendering a single large image (I have a friend
who often does this, very high res for huge advertising
boards, roadside signs, etc.)
OTOH I too have commented on the idea of having 2 systems
so that while one is rendering one can still progress with
other work on the 2nd system.
As always it boils down to available budgets, intended
tasks, etc. I'm sure we'd all love a Titan and six Teslas
on a 7-slot mbd with uber water cooling. :D
Ian.
SGI Guru
Paul Forcier
on Sep 7, 2013 at 2:27:52 am
Hey Ian you nailed it. My CB 11.5 64 bit is:
CPU - 17.13
GPU - 37.27
Ian Mapleson
on Sep 7, 2013 at 9:28:12 am
> CPU - 17.13
:D
A linear extrapolation from my Dell/X5570 results suggested
17.05; I erred on the side of caution, but I forgot your
system has slightly faster RAM. Either way, an oc'd 3930K
will give about 14 or 15 at best, so 17+ is very nice.
> GPU - 37.27
Btw, nobody really bothers with CB GPU numbers anymore.
They stopped making any useful sense a long time ago.
Ian.
SGI Guru
Paul Forcier
on Sep 17, 2013 at 5:03:27 am
Hey there - I bumped up my OC using the Blk to 3.6 ghz...
I also added another GTX 690 and engaged 4 way SLI...
My benchmark is now 3 mins and 46 seconds
Cinebench was 18.57 and without SLI for some reason it was 19.48...
Paul Forcier
on Sep 20, 2013 at 3:22:45 am
3.6 wasn't stable - moved the OC back to 3.4...all good now.
Turned off 4-way SLI and got 3 min..35 seconds.
Ian Mapleson
on Sep 20, 2013 at 10:42:22 am
Pity you had to reduce it. Ah well.
Yup, SLI is not relevant for AE/CUDA.
Ian.
SGI Guru
William Cartwright
on Sep 24, 2013 at 5:07:07 am
I don't know how I freaking got this render time, but I did. For some reason it did it in .mov first and then it switched back the second time.
.mov 1:35
.avi lossless 1:26
mb Asrock h77m-ITX
cpu: 3770k
gpu: Geforce 650 TI Boost, slightly overclocked beyond the stock o.c.
hdd: 5400 WD Green 1 TB
That's it, freaking destroyed everybody else!
Andrei Chukin
on Sep 24, 2013 at 12:26:50 pm
Nothing "destroyed")
... change the Classic 3D renderer to Ray-traced 3D... and you'll get a slightly))) different result
(Classic 3D uses the main CPU and not GPU)
Ian Mapleson
on Sep 24, 2013 at 1:03:28 pm
Just a thought, is it possible to configure the aep file so
that RayTraced3D mode is selected automatically when the aep
is loaded?
Ian.
SGI Guru
Paul Forcier
on Oct 12, 2013 at 10:51:36 pm
Stable OC 3.6 with a new bios and the 2 GTX 690 got me 3 min 22 sec
Ian Mapleson
on Oct 17, 2013 at 12:44:55 am
Interesting how the performance scaling occurs with this test,
or rather doesn't (usage per GPU isn't maxed), ie.:
4x GTX 580: 2 mins 41 seconds.
That is only just a little bit quicker than 3x 580.
Mbd is an ASUS P9X79 WS, 3930K @ 4.7, 64GB/2133 RAM, 128GB MAX IOPS
for the AE Cache.
OTOH, the result correlates quite well with Paul's dual-690, given
the 680 isn't as quick as a 580 for CUDA, so it makes sense that
4x580 would be a bit faster than 2x690.
Anyone here have 2+ Titans? That would be interesting.
I was wondering whether the higher PCIe bw of the newer P9X79E WS
would help here (x16/x16/x16/x16 for 4 cards, instead of x8/x8/x8/x8),
but who knows. Is there such a thing as a tool which allows one to
monitor the bandwidth usage of the PCIe links?
Also, have a look at the results for the Arion test, the systems
employed are kinda whacko (I'm thinking water-cooled 1-slot GPUs
for sure):
My tri-580 entry is at no. 26. I've tested 4x580, it gave a score
of 5317, which should take the no. 15 spot. 8)
Ian.
SGI Guru
Joel Bondoux
on Nov 7, 2013 at 11:06:52 pm
i7-4930K
64Gb Ram (AE configured to use 6GB per CPU core)
2 x GTX Titan (SLI)
2 x SSD (Cache & Render)
1:44 render time
Joel Bondoux
on Oct 21, 2013 at 4:05:03 pm
AMD Phenom II x4 955 BE (default clock)
GTX Titan (6Gb VRAM)
12Gb Ram
2 x SSD - one for render, one for cache
After Effects CC v2.0.0.404
Nvidia Driver: 320.49
Render Time: 4:28
Joe Presswood
Re: AE CS6 11.0.1 CUDA BENCHMARK PROJECT - test your graphics cards!
on Oct 23, 2013 at 8:47:33 pm
45 seconds
Nvidia Maximus 2.0
Quadro k5000 with Tesla k20x
Hp z820 workstation...xeon e5-2660
Teddy Gage
on Oct 23, 2013 at 9:25:13 pm
We have a winner. Where should I send your free totebag?
:D
Ian Mapleson
on Oct 24, 2013 at 1:28:59 am
Joe Presswood writes:
> 45 seconds
I hate to sound sceptical, but that doesn't sound right to me. Such
a result doesn't remotely correlate with other metrics such as Arion:
Are you sure the render is not being cached or somesuch? ie. purge
the cache and all memory before starting the test, and of course
make sure it's set to RayTraced3D, not Classic3D.
Can you post some screenshots of the NVIDIA Control Panel or
AE Preferences showing the CUDA GPU pool in use?
If it really is running that quick then it would be imperative
to find out why, but alas I doubt it's correct. :/
Ian.
SGI Guru
Todd Kopriva
on Nov 1, 2013 at 2:06:26 am
Several GPUs have been added to the list of cards that After Effects will use for GPU acceleration of the ray-traced 3D renderer in the After Effects CC (12.1) update.
See this page for details:
http://adobe.ly/AE_CC_12dot1_details
I'd be curious to see people's feedback about these cards in the newly updated After Effects using the benchmark test on this thread.
After Effects team blog
Michael Stephens
on Nov 1, 2013 at 3:43:39 am
I got a slight boost with the 12.1 AE update.
My system is
AMD Phenom X4 9750
GeForce GTX Titan
I went from 4 minutes & 33 seconds down to 4 minutes & 12 seconds.
Roberto Tafuro
on Nov 2, 2013 at 2:54:51 pm
So...i think that the GTX680 is the worst GPU here! I have changed my mobo from a DX58SO to an ASUS P6T Deluxe to add other 12GB of ram. I have an i7 980x 3,33GHz, 24GB of ram and an ASUS GTX680 with 4GB.
I've updated CC apps to 7.1 and made a test yesyerday. I've boost the GTX680 to 1245 in gpu tweaks (if iremember well, otherwise the driver will stop to work).
My time is 6,56 min or 6,58.Absolutely no change from previous AE. If i leave the boost to its default i have 7,04 min, like in the past.
What i think...i don't know...i've seen here GTX680 with 2GB made this render in 6,11 min, with a 4,xx GHz processor...but quad core (HT 8 cores i presume). I have a 6 core (12 threads) and i have slowest results...i use a PCI 2 but everywhere i read there will be no difference in this type of test. So...what's happen?
I have two Intel DCS3500 SSD (240GB for OS and 120GB for AE cache)and i have rebuilt my pc,so i have only CC apps installed, no internet connection, no process in BG (Nod 32 is closed when i work)...
Strange results here and i really don't know why. I think that the 680 is not well used by mercury in Premiere too...
I have a MXO2 mini, so i thought that the lag may come from the Matrox card and i plugged it out. No changes.
At this moment i don't see any imrpvement in this new release of AE at all.
System:
Asus P6T Deluxe
i7 980x
2x SSD (AHCI mode) Intel DCS3500
ASUS GTX 680 4GB
24GB of ram triple channel Kingston
Matrox MXO2 Mini w Max
Sorry for my bad english!
Roberto Tafuro
on Nov 2, 2013 at 5:48:41 pm
PS
Here i see on quad cores and GTX570 better results than mine...what a hell!!! :)
I have to sell this 680 really soon...
Teddy Gage
on Nov 2, 2013 at 10:03:37 pm
Yes, Gtx 5xx series have better CUDA performance than 6xx and even 7xx series cards. This is because nvidia gimped the cuda performance of these cards in favor of open gl performance. They are fantastic cards for gaming but not graphics. Currently the gtx 580 is the best performing cuda card for the money, and as the cpu is not involved, its doesnt matter how many cores you have. HOWEVER this only applies to the raytracing engine. Once you have normal 3d engine engaged, six core machines will dominate, and even I only occasionally use raytrace engine for graphics. The gtx 680 is quite a good card for open gl 3d using cinema 4d for example, so consider that as well.
Roberto Tafuro
on Nov 2, 2013 at 10:22:27 pm
Thank you Teddy for the detailed explaination. I've seen better performance in Cinema 4D and Cinebench score is higher than my previous 480. Like you, i don't use raytrace so much, i prefer Element 3D and its speed boost, but i was puzzling on why my results are worse than other previous cards!
Thank you again,
Roberto
Ian Mapleson
on Nov 4, 2013 at 3:52:07 pm
That's why I fitted my system with four 580 3GB cards. :D
For 600/700 series, NVIDIA halved the clock rate of the
shaders (they did this to help with power/heat issues I've
been told), so a lot more cores are needed to match a 500
series card for CUDA. Also, the 500 cards have much more memory
bandwidth available per core, so they're more efficiently used.
The newer cards are faster for standard gaming 3D tasks, but not
CUDA, at least not for 32bit fp anyway.
Teddy, just a thought, should we include AE 12.1 results at all
in this thread? It might confuse people. Perhaps a new thread
for 12.1 data? Or at the very least ask posters to make it very
clear which version of AE they're using.
Ian.
SGI Guru
Roberto Tafuro
on Nov 5, 2013 at 1:25:30 pm
Thank you Ian. I don't want to make OT,because this thread is about benchmarks,and i must admit that one or two minutes more doesn't make kill myself (in the "night-render" world you know,the important thing is to make all right and don't need to render again!),but i don't understand why a GTX680 with 2GB renders in 6.11 min and a GTX680 with 4GB renders in 7.4 min. If we are talking about ray trace and GPU render and if i understand how it works,the CPU and ram (system ram) doesn't make difference in this kind of test. So a GTX 680 will render in approx the same time on every system. Is it correct? PCI 2 or PCI 3 as i understand come in place when you use SLI so a PCI 2 doesn't make a difference on a single card.
I have the same result with an Intel DX58SO mobo and with an Asus P6T Deluxe. So it's not a problem of mobo and it's not a problem of the GTX680. As i said it's a new rebuilt machine with two SSD,24 GB of ram (i know that is not a huge quantity,but i work very well and ram usage never goes up to 50% in render queue) and a i7 980x...so i don't think that i have a low end machine...
I've tried to boost the card in GPU tweak,but i'm not able to oc a card and the fear of screw something is too much,so i prefer to work with standard settings...
I'll stay with this values and be happy with the card,but the 50sec differences from the result i've seen here with another 680 is really strange to me...
Maybe there is a way to use better the GTX680?
I don't know!!!
Thank you again for your time and patience and sorry for my bad english!
best regards,
Roberto
Ian Mapleson
on Nov 5, 2013 at 1:46:01 pm
Roberto Tafuro writes:
> to make all right and don't need to render again!), ...
The people I help want both. :D Fast & reliable.
> ... but i don't understand
> in 7.4 min. ...
Probably the latency is different because of the way the RAM is setup using
different ICs. And are you sure both 680s have the same core/RAM/shader clocks?
> ... So a GTX 680 will render in approx the same time on every system.
> Is it correct? ...
More or less, yes. I'll be testing this to the extreme soon using an i3
550 system and four 580s, but so far I've not seen any excessive
differences with respect to the test platform being used.
> ... PCI 2 or PCI 3 as i understand come in place where you use
It might also matter when using multiple GPUs even without SLI, though
I was told the return path for gamer cards is only x1 speed anyway so
it doesn't matter, but yes in this context I doubt it matters.
I wouldn't use any of the 600 series cards for CUDA. I realised this was
the case when the first reviews were published. Plus, back then, none of
the 600 cards were quicker than my two 560Tis SLI so I didn't think it
worthwhile even for normal 3D gaming performance. Now I have two 580s
SLI which is faster than a 780 for gaming and waaaay faster for CUDA;
hence, my CUDA research machine has four 3GB 580s, and I've just obtained
another MSI 3GB 580 L.E. which should oc to 1GHz+ (I was able to give it
a quick run at 950MHz no problem; see http://www.3dmark.com/3dm11/7390717).
> strange to me...
Hard to know for sure, but check those clocks with GPU-Z, and as I say
the latency through the RAM could be a factor.
Yes; for CUDA, sell the 680 and use the money to buy a 3GB 580. :D
You're kidding right? You have better spelling, punctuation, grammar,
etc. than most Brits. :D
Cheers! :)
Ian.
SGI Guru
Muammer Özvardar
on Nov 7, 2013 at 1:04:33 pm
Hi there, i saw this treat newly; also i'm nearly new to after effects. Doing somethings fun for now.
My system: i5-2500K@4.2ghz 16ghz 1600 ddr3 120gb ocz agility 3 zotac gtx680 amp! 2gb win7 sp1
Render result gives: 6min 24sec
It really pushs gpu on heavy-load due fan gets work more faster while rendering :)
Roberto Tafuro
on Nov 10, 2013 at 12:47:55 am
Thank you Ian for the kind words! It's difficult to explain something in english for an italian like me!
I have to be honest,i'm a bit tired of build and rebuild my machine. I'll live with the GTX680...at least is quiet and cold!
Hi Muammer!
So your GTX680 amp renders the comp in 6.24. It's almost the same result of another 680 here in this thread. I think that the other one must be an amp version too...
Nacho Gomez
on Nov 12, 2013 at 3:51:24 pm
Hey I ran you benchmark on my build, it's a hackingtosh running OSX 10.8.5
i7 3770K
32Gb 1600Mhz RAM
2x SSD (system/apps and chache)
GTX 570 1,25Gb RAM
I got it done in 5:49. Not bad!
Mike Tyo
on Nov 16, 2013 at 3:27:55 am
First post here. I just upgraded my old Mac Pro 5.1 to a pair of CUDA cards: a flashed FTX 580 3GB and a stock 1.25GB GTX 570. The two of them play very well. With just the 580 my best time was 5:43. With both cards installed and running, my time was 3:19. I'm astonished that these cards scaled so well!
Ian Mapleson
on Nov 16, 2013 at 10:14:57 am
The scaling does drop off somewhat after two cards, but more
still helps, though I found the gain from three 580s to four
580s isn't that much. I suspect it's probably not worth having
more than four 580s, ie. for the performance gained vs. extra
power consumption, etc.
Ian.
SGI Guru
Dmitry Kitsov
on Nov 20, 2013 at 2:50:16 am
3x GTX Titan
Windows 8.1
1:32
Ian Mapleson
on Nov 20, 2013 at 10:44:43 am
Excellent!! Now we're talking! 8) Is that tri-Titan time
done with the Titans running at stock speeds?
Ian.
SGI Guru
Dmitry Kitsov
on Nov 20, 2013 at 7:36:24 pm
Yes, though one is EVGA factory "Superclocked" at 875. Other two are at 836. I am also running them at PCIE2 not 3 (no mobo support for PCIE 3)
Ian Mapleson
on Nov 25, 2013 at 12:15:04 pm
Sweet!! 8)
Note that I doubt the PCI 2 vs. 3 config makes any difference
for this particular test.
So, now all we need is a result from someone who has one
or more 780 Tis (should in theory be quicker than Titans).
Ian.
SGI Guru
Steven Andrus
on Jan 7, 2014 at 6:22:55 am
Dual Xeon e5-2690 at 2.9ghz (speed step kicks it up to 3.2 or something I think but I didnt see the render really hit the cpus at all so i think it stayed at 2.9)
64gb of 1600 ram
windows 8.1
Single asus titan 6gb
ran the benchmark with a browser open on another monitor driven by the same gpu and had a few other apps open and system monitor open. I also ran it with one display and separately with caps lock on, same time every time. Honestly we should be running this at 4k though. I'll look into converting the file into 4k and link it if I do.
Render time: 3:13
Ian Mapleson
on Jan 7, 2014 at 9:57:37 am
Steven Andrus writes:
Yeah, does that on my Dell T7500, usually stays at one BIN above the baseline.
It'll barely touch the CPUs at all, being a CUDA test.
Real-world datasets can hammer the CPU(s) aswell at times, but not this
test, it's pretty simple & repetitive.
Just FYI, a 780Ti should be quicker.
Not sure it's worth doing. All it would do is quadruple all the running
times, except systems where RAM on the GPU suddenly becomes an issue and
they'd be even slower, even though such cards aren't fit for 4K anyway.
Running it at 4K wouldn't reveal anything new.
This test is interesting as a means of testing one narrow performance
aspect of AE (namely CUDA on a small dataset that doesn't hit CPUs, RAM
or I/O), but for me it's thrown up questions for which I can't find
answers, eg. is it possible to force AE to use multiple GPUs round-robin
for frame rendering? AFAIK atm the app always tries to use all available
GPUs at the same time for every frame, which often scales very badly
indeed (extremely badly in some cases). Look at my multi-580 results for
a good example (see earlier posts): with more than 2 cards, the
exploitation percentage of each GPU drops off sharply, so four 580s is
barely any better than three. Performance would be much better if the
frames could be rendered 1-frame-per-GPU, so with 4 GPUs the first GPU
would render frames 1, 5, 9, etc. I can't see any setting for this in the
Settings panel though.
The other question is, does AE ever make use of 64bit CUDA? That's the
only real advantage of Titan. Are you running the Titan in 64bit mode?
If not, try it in 64bit mode, see what happens, though that would
probably only reveal whether this particular tests gains from 64bit mode,
not whether AE uses it in general, and if so then to what degree. If AE
doesn't need 64bit CUDA, then (except for the lack of ECC RAM) the best
value CUDA card atm for AE is the 780 Ti, unless somehow one is running
up again the card's 3GB RAM limit. Most likely though some vendors will
eventually release 6GB 780Ti models.
The final question is whether AE would benefit from the full speed PCIe
return paths found in Tesla cards, and the better GPU cache structure &
other additional features. Is AE even coded to make use of these? Who
knows - there's nothing on the Adobte site about this.
A friend of mine is working on a more real-world dataset, a 30 second
animation which atm takes about 2 hours with a couple of 580s. It hammers
the whole system and so is a good general test, including system stability.
Not ready yet though.
Ian.
SGI Guru
Tyler Tometich
on Jan 10, 2014 at 12:57:00 am
Mac Pro (MacPro5,1)
2 x 6-Core Intel Xeon @ 2400 MHz
32 GB - DDR3 ECC @ 1333 MHz
NVIDIA GeForce GTX 680 2GB
OS X 10.9.1
RENDER TIME - 6 Minutes 46 Seconds
*dIGITAL cREATIONS*
-Mac Pro (MacPro5,1)
-2 x 6-Core Intel Xeon @ 2400 MHz
-32 GB - DDR3 ECC @ 1333 MHz
-NVIDIA GeForce GTX 680
-Canon 5d Mark III
-Adobe Creative Suite CC
Cyra Emery
on Jan 17, 2014 at 9:42:31 pm
I must be doing something wrong as it finishes in 17 seconds on my hackintosh.
2x GTX Titan (EVGA Superclocked), E5-2695 V2 2.5GHz 12-core (5% OC on it), 64GBs 1600Mhz ECC RAM with an external SAS Raid.
mavericks 10.9.2 (1st beta).
Ian Mapleson
on Jan 18, 2014 at 10:40:31 am
Most likely it's being cached somehow, or it's rendering in Classic 3D Mode, something
like that. Just go through the settings, make sure each is as it should be, and of
course ensure all caches are cleared before starting the test (media, disk & RAM).
Ian.
SGI Guru
Steven Andrus
on Jan 18, 2014 at 8:06:24 pm
You probably forgot to clear out your ram preview
yakup babalı
on Jan 22, 2014 at 8:09:19 am
AE CC
ASUS Z87-PRO Z87
INTEL 4770K
32gb DDR3-1600Mhz RAM
Samsung Electronics 840 Pro MZ-7PD256BW SSD
1. test
Quadro K4000
14 Min 20 Sec
2. test
Gigabyte GV-N780OC-3GD
3 Min 29 Sec
on Feb 14, 2014 at 4:57:29 pm
Should I just use the test in the first post and convert the project to CC? no fidling with anything? just export out?
Michael Stephens
on Feb 19, 2014 at 3:48:45 pm
Correct. Load the file, make sure you have the comp set to Ray-Traced 3D, then send the comp to the render queue.
Ian Mapleson
on Feb 19, 2014 at 5:54:08 pm
And remember to clear all memory & disk caches before
running the test. Also make sure RayTrace3D is turned on.
Ian.
SGI Guru
on Feb 28, 2014 at 7:47:01 pm
Get in! Done in 3min 12secs!
Rig is as follows:
MOBO: ASUS P9X79E-WS
CPU: Intel i7 3930k STOCK (3.80ghz TURBO 6 core)
RAM: 64GB DDR-3 1600Mhz Kingston HyperX Gen
GFX: EVGA GeForce Titan 6GB
DRIVE1: SAMSUNG EVO 840 120GB (Windows + apps)
DRIVE2: 2xSAMSUNG EVO 840 120GB - RAID-0 (CACHE)
DRIVE3: 2xINTEL 520 240GB - RAID-0 (PROJECT- WORK)
DRIVE4: 2x WD Black 2TB - RAID-1 (STORAGE)
OS: WINDOWS 8.1
MONITOR: Dell UltraSharp U3011
AUDIO: Saffire Focusrite 24 DSP Pro
SPEAKERS: 2xJBL LSR2325P
FIREWIRE: SIIG DP FireWire 800PCIe - TI XIO2213
BURNER: Lite-ON iHBS312 - BR-R+DVD+RW
COOLING: Intel Liquid Cooling Solution - RTS2011LC
CASE: Fractal Design XL R2 Black Pearl
PSU: Corsair AX1200i - 1200W
CAPTURE CARD: Blackmagic DeckLink 4K Extreme SDI
SCOPES: Blackmagic SmartScope Duo 4K
UPCOMING PURCHASES:
CPU: 1x Intel Xeon E5-2697 V2
GFX: 2x EVGA GeForce GTX Titan 6GB
on Feb 28, 2014 at 8:30:41 pm
Right, screenshot or it didint happen as they say. Ran the test again, as I forgot the screeny the first time around. Lost 1 sec which makes it 3:13 now.
P.S Everything in our system is stock. No OC at all on any of the parts.
Ian Mapleson
on Mar 2, 2014 at 11:30:45 am
Thanks for the result!! I'm looking forward to hearing how
the test scales with the extra Titans. Also, can you run the
ArionBench test aswell? Both CPU & gfx? Would be interesting
to see how CPU performance differs to the XEON 2697 once you
have it installed.
My system has the older ASU P9X79 WS (3930K @ 4.7, 4x GTX 580
3GB). How have you found your newer E-WS board in terms of
setup and usage? Any issues?
Ian.
SGI Guru
on Mar 2, 2014 at 7:58:49 pm
Hi Ian. Glad we could contribute. Regarding our current motherboard. Its great, really. Not a single crash or anything, easy to config and setup.
I reckon the bios is pretty much the same as your's to be honest. I would advise though, to get a separate RAID controller if you have several drives, the Marvell 6Gbs controller is absolutely horrendous compared to the Intel. Even in RAID-0 the Marvell 6Gbs struggles to reach the speeds of a single drive in the Intel 6Gbs. I am absolutely clueless as to why ASUS dosent just have only Intel RAID controllers on their boards. Would be much better.
But no, no issues in terms of errors. :) And now yes, they added the support for the new Xeons with the latest bios update, so we can just switch over to the 2697 V2 when we want, and on that note; I will test our system with Arion now, note the results and test again when we get the extra TITANS and CPU :)
Ricardo van den Berg
on Mar 3, 2014 at 8:35:26 pm
LAPTOP: MSI GT70 ONE late 2013
Intel I7 - 3630QM ( 4 cores, 4 threads at 3,4 GHZ )
Chipset Intel HM77 Chipset
Memory DDR3 1600MHz, 4 slots, 8 GB
Graphics nVIDIA Geforce GTX680M ( compairable with the dektop gtx 660 TI , its a downclocked gtx 670 for what i've heard )
Graphics VRAM GDDR5 4GB
+ ofcourse the intel hd graphics 4000
HDD (GB) 750GB HDD at a speed of 60 to 80 mbps
benchmark: 10 minutes and 35 seconds
does anybody know what my best upgrade will be?
- 1 msata ssd
- more ram
- 2 msata ssd in raid 0
- throw away system?
Rudi Kirschen
on Mar 30, 2014 at 11:52:05 am
so here is my new system:
2min 43sek
CPU: 4930k @ 4.4Ghz
RAM: 64Gb Corsair Venegance Pro 1866Mhz
GPU: Asus GTX Titan Black 6GB VRAM
Macbook Pro Retina with GT 650M wouldn´t even start to render. i canceled after 10min and not a single rendered frame. Maybe caused of the few vram of less than 1GB
but with the titan black setup i am pretty happy
ali demirtaş
on Apr 10, 2014 at 7:47:18 pm
cpu: xeon e5-1650 @5ghz oc
gpu: zotac 780 ti 1240x7800 oc
ram: 32gb kingston 2133
2min.21sn
Paul Roper
on Apr 14, 2014 at 1:47:37 pm
So...after all this research and testing, can anyone suggest where I could get a reasonably high-end AE system, preferably a Hackintosh, built? I haven't got mega-money to throw at it, but I'd obviously like something that's future-proof(ish) and can run AE (plus Premiere, Photoshop and some 3D - probably C4D) at a decent pace. I don't need any video in/out. Most of my work will (for now) be 1920x1080, so no need (yet) for 4K support.
Ideally, I'd like the power of a new Mac Pro (preferably with more powerful graphics) for the price of an iMac. Or less! I've had a quick look through some other Hackintosh sites, but most people's ideas of a powerful computer is not the same as an AE user's idea of a powerful computer; hence asking in this forum for some advice.
My Mac Pro (on loan to me from my previous employer) has been taken away - I'm now properly freelance again, but I'd like something of similar spec. It was 2011 model with 2x 6 core 3.06GHz Xeons, 64GB RAM and 2x 2GB Quadro 4000. And it cost a lot!
If I can get more power for less £££, then I could be persuaded to make the jump to a PC.
I know this is all a bit vague, but I'm trying to get an idea of what price/performance I can get.
- Paul
Teddy Gage
on Apr 14, 2014 at 4:11:03 pm
Hi folks, thanks everyone for contributing to this project, it was a real eye-opener. However I am no longer supporting this benchmark, I have a new project that does total CPU / RAM / GPU testing in AE CC here:
http://www.teddygage.com/AfterBenchCC/
RESULTS:
Add yours! email me at fstopdigital@gmail.com or on twitter @teddyrocksteady
http://goo.gl/JrNIXd
@ Paul Roper -
I would NEVER rely on a hackintosh for real production work. They are too unreliable even if you know what you are doing. And even if built by a 3rd party (which will never happen, because they are breaking the law) you need to know how to work with a PC way before you'd consider messing around with faking OSX bootloaders and the like. They require a very specific combination of hardware and many features remain unsupported. Not to mention the hardware will be limited - you are probably losing a good percentage of CPU performance because it is not perfectly tuned for the OS.
You may be better off saving up for a new mac pro, although I've heard mixed reviews.
Honestly, my advice would be, if you are looking to stay Mac, is to look on the used market (ebay, classifieds) for a topped-out, but used, last-gen Mac Pro with the specs of your old work computer. You may be surprised what you can get for way less money.
Additionally, I have heard firsthand that the new mac pro GPU implementation is really crappy. The only app to seriously take advantage of their power is FCPX, and who cares about that. Not to mention zero CUDA or directX support. So I'd recommend looking at a PC with 2x GTX Titan or 2x GTX 780 in SLI if graphics is truly your priority. Yet you claim you need the speed solely for AE, and the GPU dependent effects are few and far between, unless you use AE raytracing all the time. People seem to believe GPU performance is all that matters when that couldn't be further from the truth.
So I would save money and focus on getting a capable graphics card and spending money on CPU - you would want an overclocked intel i7 3930K or 4930K hex-core CPU - which in many tests on the benchmarks above performs much faster than dual-quad xeons. In a pc environment it is currently the fastest consumer processor on the market for after effects.
If you are out for pure speed in AE, you should switch to windows. I'm sure people will disagree, but there is no mac out there that touches the price / performance ratio of a custom built pc workstation. I'm not biased: I own and use both systems, but I would never do 3D work on a mac, and only do AE stuff on OSX in a pinch.
Paul Roper
on Apr 14, 2014 at 4:23:21 pm
Thanks for that, Teddy.
I think you've confirmed my suspicions - making the jump to the world of Windows is probably the way to go. I need to do some serious research on what's out there in the world of Windows boxes that's great for AE. I'll be reading through the results of your new benchmark test with great interest.
Thanks again,
Paul
Roy Foliente
on Apr 14, 2014 at 7:08:45 pm
I agree with your comments, Teddy. I think they are spot on. I, too, am in the process of evaluating my next hardware platform for both Premiere Pro CC and AE CC work. Coming from the Windows side, I thought it was a forgone conclusion I would get another Windows box. My only complaint with most Windows boxes are they very noisy and typical of most serious workstations, they pay no heed to energy efficiency, which is a shame. This is the strength of the new Mac Pro to me. I just returned from the NAB (National Association of Broadcasters) meeting in Las Vegas last week and spent a lot of time in the Adobe booth. I can tell you Adobe is now very "bullish" on the new Mac Pro. They were previewing their next release of Premiere Pro and AE and their booth was littered with Mac Pro machines. They were using Mac Pros for almost of of their presentations and as they showcased some of their new features, they ran very briskly. Apparently, their new release (due out next month?) will fully leverage the new Mac Pro hardware including the dual AMD gpus. While only a single CPU workstation and limited in its expansion capabilities, it might be premature to completely dismiss the Mac Pro for serious CC work. I hope your benchmark can be modified to include the new CC release when it comes out.
Roy
Hendrix To
on May 4, 2014 at 4:37:30 am
4 mins 1 Sec
I think it a good one for 2010 base line Mac pro with only 8G of RAM .
with a change to Flashing and Mod GTX 780 , 3G Memory . going to add more Ram for it ..
Tenchi Muyo
on May 15, 2014 at 7:18:58 pm
4960X@4Ghz with 3-way-Titan SC classic:
Ian Mapleson
on May 15, 2014 at 10:38:16 pm
Tenchi, am I reading that correctly? 2 mins and 3 seconds? Strange, I thought
it would be a lot quicker with three Titans...
Anyway, I've finished upgrading my 3930K system, it now has four identical
MSI GTX 580 3GB Lightning Xtreme cards; at stock core speed of 832MHz I get
1 min and 40 secs:
Oc'ing the cards doesn't help much, eg. at 900MHz the time only drops to 1m 35s.
Ian.
SGI Guru
Teddy Gage
on May 15, 2014 at 11:19:40 pm
Ian, I have a new suite of total benchmarks, not just GPU. Would love to see your results on these. I am no longer supporting this outdated benchmark, although of course you are free to use it.
RESULTS:
PS. What on earth are you using 4 GTX 580s for? Bitcoin mining?
Ian Mapleson
on May 16, 2014 at 12:02:37 am
Teddy writes:
> your results on these. ...
I'm still using the normal CS6 11.0.4; am I right in assuming your new suite needs AE CC?
Thanks! It has certainly been useful, though I've been working with someone
on creating something a lot more complicated and better able to exploit multiple
GPUs: one frame takes about 10 minutes to compute with three 580s, while the full
animation takes many hours to render (tomshardware will be using the scene file
for their CUDA tests when it's ready).
Mainly research into performance issues with AE and other computational
benchmarking experimentation. It's a clone of a system I built for someone
a year ago, though better setup in some ways with lessons learned. Here's
an up to date CPU-Z:
http://valid.x86.fr/r9ibvb
The CPU oc isn't finished yet though, haven't done the final tweaks or evaluated
the max speed (it was set to 4.7 with the old cooler, a Phanteks PH-TC14PE; new
cooler, now in a different case, is a Corsair H110).
Ian.
SGI Guru
Tenchi Muyo
on May 16, 2014 at 8:14:46 am
@Ian
I'am using CS6 so i think it dont use all 3 of my Titans - only one Titan is used,
or i'am wrong?
Ah, ok the output files were written on my WD Velocirator HDD, now i use my Samsung 830 SSD (512GB):
now the time is:
1 min. 29 sek
+ 5 Sek.
So HDD/SSD influence this test.
BTW: nice card the MSI Xtreme Lightning i had this card too, i loved it!
Using the Samsung 840PRO (512GB)SSD (my C: drive)
and the testfile on D (my Samsung 830):
the time is:
2,23
and
3 sek.
All path are by default - wow thats much slower!
Ian Mapleson
on May 16, 2014 at 9:00:44 am
Tenchi writes:
> now the time is:
> 1 min. 29 sek
That's better, although still slower than what I would have
expected from three Titans.
> + 5 Sek.
What is this second time for? No point running the test
twice, it will all just be cached data.
Hmm, maybe I should try again then, I was writing to
a mechanical drive RAID1.
> too, i loved it!
Indeed. :D I've obtained five of them so far. One thing
though, they're a pain to install when there's more than
two. The card is more like 2.1 slots wide, not 2 slots.
I've had to use spacing pads to keep them apart, otherwise
the fan blades clash.
I don't quite understand your 2nd time; do you have a
separate SSD for the AE cache? You should do.
Ian.
SGI Guru
Tenchi Muyo
on May 16, 2014 at 9:11:35 am
No, i have all on default C: (clean install) all "temps" for AE & AP is drive c:
The 5 sek. is not a second run (of cached files)
it renders two compositions.
See my first bench picture
Ian Mapleson
on May 16, 2014 at 9:28:13 am
Tenchi writes:
That's not the recommended setup. The AE cache should be
on a separate fast device, preferably an SSD.
I also have a separate 64GB SSD for the Windows paging file.
> i renders two compositions.
For this benchmark, it's just the main render time that's relevant.
Ian.
SGI Guru
Tenchi Muyo
on May 16, 2014 at 9:35:42 am
Thanks i will change it in the future! :)
I found this test because i want to check if the "hack" works for my Titan.
Adobe says it doesn't work because only the card name is regognized.
My 4960X cpu render this bench in 3 hours it says but i didn't finished the bench because it takes too long.
I'am thinking about to change my 3 Titans to 1 Titan Black (because of SLI problems in games).
Is there a bench with the Titan Black?
Ian Mapleson
on May 16, 2014 at 10:19:30 am
The adjustment to the supported cards file should work fine,
just make sure the name matches the identifier string in GPU-Z.
In your position I'd stick with the Titans, though for AE the
780Ti is the more sensible card to use, or it will be once we
can get a 6GB edition.
Ian.
SGI Guru
Tenchi Muyo
on May 17, 2014 at 1:16:19 pm
Does CS6 use all of my 3 Titans for rendering ?
(I thought its only possible since CC..)
Because i found this video with a Quadro K6000 and it takes 3:27m
Another comment for the video:
"Asus Geforce Titan in 3 minutes 12 sec
Systemspecs Intel I7 4930K and 32 GB"
With my 1 min. 29 sek it used all my Titans right?
Or are the times only the difference that one wrote the outputfile on HDD and me on SSD ?
EDIT:
Ok, CS6 uses alle my three Titan cards, i insert only one card and the time is:
3:03 min. @ 1xTitan SC
1:47 min. @ 2xTitan SC
1:30 min. @ 3xTitan SC
I had in the moment problems with my 3-way-SLI Far Cry 3 shutters like hell,
now i found out my third pcie slot is damaged - so i cant do a test with all three cards at the moment. :(
Ian Mapleson
on May 17, 2014 at 6:05:12 pm
Tenchi writes:
Yes.
NOTE: this benchmark does not scale that well across
multiple GPUs. The usage of each GPU with 3+ is not
linear. That's why the time does not drop very much
when adding a 3rd Titan.
> shutters like hell,
Could be a driver issue, or the wrong SLI profile. Mind
you, I'd have thought 3-way Titan is a bit overkill for FC3.
Ian.
SGI Guru
Tenchi Muyo
on May 17, 2014 at 7:14:21 pm
I fix the Far Cry 3 shuttering with a CMOS clear/reset an reinsert the cards,
during this i destroyed my third pci-e slot for my third Titan.:(
Ian Mapleson
on May 18, 2014 at 4:34:40 pm
Can you RMA you motherboard? What model is it? (just curious)
Note that Gigabyte GA-X79-UD3 boards sell quite cheaply these
days - I bought one for only 65 UKP recently.
Ian.
SGI Guru
Tenchi Muyo
on May 19, 2014 at 12:50:28 pm
No, it was my fault as you can see in my first screen i had 3xtitan and 1xgtx680 classified in my pc,
i want to remove the gtx680 and it makes real problems so i damaged the pci-e slot.
No cards are recognized here.
It was a Asus REIV mobo, today i get two boards:
the REIV and the Black Edition of the REIV.
My wish is to take the Black,
but i have this for months ago but it has a lots of problems
(pc turns off during slight cpu usage).
Otherwise I choose the good old REIV,
because it runs perfect - one advantage of this board:
when using 3-way sli you have between all cards one slot free.
I'am thinking about the ASUS P9X79-E WS too, but with most cpu coolers the first pci-e Slot is blocked. Then it has two PLX Chips (of course) but this raise the power consumtion and heat and maybe i will get some (additional) lags during gaming. So i won't risk it.
Another interessting board: ASRock Fatal1ty X79 Champion
but it has a big problem in my eyes:
the fourth pci-e slot runs only at PCIe 2.0 and never PCIe 3.0 (the other three PCIe did).
Running a mobo with pcie 3.0 x8 is the same speed as pcie 2.0 x16.
Ian Mapleson
on May 19, 2014 at 6:44:57 pm
Tenchi writes:
> pci-e slot.
Sorry to hear that. :\
You never know though, it may be worth trying to get the damaged
board returned under warranty. Have you tried?
> but i have this for month ago but it has a lots of problems
I assume the BIOS & drivers are all up to date, yes?
> Otherwise a choose the good old REIV, because it runs perfect - ...
That's similar to why I like the P9X79 WS (basically the same type of
board as the R4E); the newer E-WS has a better PCI Express setup, but
people have reported more problems with it. The standard WS is very
reliable (I'v ejust bought another one, only cost 170 UKP).
> ... one advantage of this board:
Ah yes, that's why I liked the Asrock X58 Extreme6, it has a complete
empty slot between each card for 3-way CF/SLI. Alas this is not the case
with the WS, but it doesn't matter because I chose the MSI LE version of
the GTX 580 (runs much cooler, totally different design to the reference
board, designed to cope with oc's above 1GHz).
It's a pity nobody makes a super-extended board with 7x PCIe, spread
across at least 10 slots, giving much more cooling space between cards,
and greater options to exploit additional cards such as RAID or 10GigE.
> the first pci-e Slot is blocked. ...
I had this issue initially (well, sort of; the HS pressed up against
the back of the first GTX 580), because I was using a large Phanteks
PH-TC14PE. I've solved this by replacing the Phanteks with a Corsair
H110, so now there is plenty of space around the CPU area, much easier
to access RAM, cool components, etc.
For the next 3930K system I'm building for someone just now, I'm using
the same mbd but fitted with a Corsair H100i instead.
For gaming I'd say you're better off with the R4E series. The advantage
of the WS is better support for RAID cards and more reliable with maxed
out RAM configurations, heavy loads, etc. Gaming doesn't really stress
the whole system that much, but various pro apps do, eg. AE can hammer
all parts of a system at once, far more than any game.
> three PCIe did).
How odd...
I doubt it would make any difference in reality, but I can understand
why it would feel annoying.
There is of course the Asrock X79 Extreme11, but that's overkill, not
really aimed at gaming. It's more akin to the ASUS WS series, though
the lack of onboard RAID cache spoils it IMO.
Ian.
SGI Guru
Tenchi Muyo
on May 20, 2014 at 8:41:41 am
updated my post with the 3xTitan:
Ian Mapleson
on May 20, 2014 at 9:17:14 am
Tenchi writes:
Glad to see my original idea that 4x580 would be akin to
2xTitan is correct. Hopefully though soon I'll be able to
show how multiple GPUs can scale more effectively than
this benchmark is able to demonstrate; test file is not
quite ready yet.
EDIT: Quadro K5000 does the test in 8 mins and 4 secs,
though this was on a different system with a lot less RAM
(ASUS M4E, i7 2700K @ 5GHz, 8GB/2133).
Ian.
SGI Guru
Tenchi Muyo
on May 24, 2014 at 11:17:16 pm
New Bench :)
4960X@4Ghz / Asus REIV / 64GB RAM
4960X@4Ghz / Asus REIV Black Edition/ 64GB RAM
2:48 min. @ 1xTitan Black SC
BTW: here is another Bench "robot" for AE:
http://www.loopoutcontinue.com/cuda/
Ian Mapleson
on May 26, 2014 at 7:56:12 pm
Just curious, what did you do to speed up the result for
the single Titan? Or is it purely the change in mbd?
Btw, I find Arion to be a useful test, as it fully utilises
all GPUs (AE doesn't do that yet).
Ian.
SGI Guru
Tenchi Muyo
on May 26, 2014 at 9:13:42 pm
I sold my Titan Classic cards.
Now i own ONE Titan Black.
Thats the speed difference.
Ian Mapleson
on May 27, 2014 at 12:54:25 am
Oh I see! Apologies, I missed the different name of the
Titan card. :D Just curious, what is the core clock of
your Titan Black compared to the Classic you had before?
Btw, a couple more data points, using a 5GHz 2700K setup
with 32GB/2133 RAM):
Quadro 6000: 8m 7s
2x Quadro 6000: 4m 36s
Also, in case it's of any interest, I've added some
Viewperf12 data to my site, for the moment using the
above 2700K system (which shows some major CPU bottlenecks
in several cases - looks like Viewperf12 needs more than
4 cores):
http://www.sgidepot.co.uk/misc/viewperf.txt
Ian.
SGI Guru
Ian Mapleson
on Jun 11, 2014 at 1:08:50 am
Another GTX 580 data point:
4x EVGA GTX 580 1.5GB (797MHz default): 1m 43s
This test definitely doesn't scale so well beyond 3 GPUs. Still, the above result
with four cheap 580s at least shows the economy option for those who can't afford
780/Tis or Titans. 8)
Ian.
SGI Guru
Tenchi Muyo
on Jul 6, 2014 at 1:06:35 pm
New Bench :)
1:36 min. @ 2xTitan Black SC
Teddy Gage
on Jul 10, 2014 at 1:51:55 pm
Nice scores!
Quick question: i am actually hunting for a gtx titan NON black edition ( ie original) to speed up a project im working on. I already have one titan and want the other for SLI. Anybody in this thread willing to sell a used one at a reasonable price? They are actually difficult to find on the used market...
I have 100% positive feedback on ebay and would actually prefer to arrange the sale through there if possible. Or in the nyc area through a craigslist type sale...
Ian Mapleson
on Jul 10, 2014 at 3:51:15 pm
Teddy writes:
Just wondering, do you really need the 6GB RAM? If not, you're much better off with a GTX 780 Ti,
which will be faster than a standard Titan and cost less than a used Titan. Also, there's no need
to link them SLI for AE, it has no effect, unless you're using the same system for games aswell. ;)
> ... Or in the nyc area through a craigslist type sale...
NY? Cool!! Best city I've been to so far IMO. T'was 14 years ago, but I'd like to go again someday.
Ian.
SGI Guru
Teddy Gage
on Jul 10, 2014 at 4:51:24 pm
I would like the 6GB RAM, it does get eaten up by AE in big scenes, especially in 2k and up. There can be stability issues without having matching cards, I have found in the past. Additionally, I do want the option of SLI for gaming.
However does anyone know how C4D R15 handles dual GPU setups? Does SLI make a difference? Can it utilize two different GPUS like AE?
Ian Mapleson
on Jul 10, 2014 at 7:13:34 pm
Teddy writes:
> I would like the 6GB RAM, it does get eaten up by AE in big scenes, especially in 2k and up. ...
I guess that figures.
> ... There can be stability issues without having matching cards, I have found in the past. ...
Ah, so you already have one Titan?
> ... Additionally, I do want the option of SLI for gaming.
Another Elite Dangerous addict in the making. ;)
> However does anyone know how C4D R15 handles dual GPU setups? ...
I assume by that you mean with the octane plugin, yes? Octane Render
can exploit multiple GPUs ok, and they don't have to be of the same
type at all.
> Does SLI make a difference? ...
Very unlikely. It shouldn't do for any kind of rendering task.
> ... Can it utilize two different GPUS like AE?
Yes. See:
http://render.otoy.com/manuals/Standalone_2_0/?page_id=20
http://render.otoy.com/manuals/Standalone_2_0/?page_id=52
Ian.
SGI Guru
Teddy Gage
on Jul 10, 2014 at 8:02:18 pm
Yep, already have one titan, so the performance bump is worth it for a reasonable price, it could actually double my workflow speed.
In terms of C4D I was talking more about C4D viewport performance, not octane rendering, although it would be a good setup for that too.
Ian Mapleson
on Jul 11, 2014 at 1:48:25 am
Teddy writes:
Ah I see! Yes indeed, though I doubt there would be any problem with using a non-reference
Titan, or a Titan Black.
> I was actually talking more about C4D viewport performance, not octane rendering,
Ah, now that I don't know. Sorry!
Ian.
SGI Guru
