Remove Shadow and Light from CC Sphere, or create non-lit 3D sphere?
Morgan 'Jill' B
on May 23, 2012 at 7:17:13 am
Hello,
I am looking to make a 3D map, so was going to use it on a sphere, like a globe. However the shadow that CC Sphere adds to it is pretty severe and I didn't want a shadow at all.
How best to apply a flat map to a 3D object, to enable quick and smooth jumping animations from country to country?
Thanks!! :)
John Cuevas
Re: Remove Shadow and Light from CC Sphere, or create non-lit 3D sphere?
on May 23, 2012 at 2:20:41 pm
If you open the shading slider and turn the ambient to 100 and the diffuse to 0, you will remove most of the shading and be pretty close to the default colors of you original map.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
