Connected lines (question)
Maverick Mooney
on May 23, 2012 at 3:31:51 am
Okay, so i came accross this edit on youtube:
and the most noticed effect is this sort of line effect you see almost right off the bat. I was wondering how i could be able to achieve this effect? I have a feeling it has something to do with the beam effect, shape layers, and expression. But i am not sure where to start and how to attempt this. It would be greatly appreciated if someone could help me out! <3
John Cuevas
Re: Connected lines (question)
on May 23, 2012 at 1:50:17 pm
Couple of plugins will do it. That one in your example looks like Plexus. There is also another one called Nodes, but I don't think it's as powerful as Plexus. I haven't experimented with either so I can't tell you much more than that.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Maverick Mooney
on May 23, 2012 at 7:36:43 pm
Thank you soo much!
Sorry if it was an amateur question but im only 15 getting into vfx :/
