remove a color cleanly and replace with another
Lori Newman
on May 19, 2012 at 6:00:23 pm
I have a client job and need to easily and cleanly remove a color from and image
and replace it with another. the colors aren't in solid blocks. I tried replace color
with no luck. Does anyone have a suggestion of a plugin or other way to do this?
thanks!!!
Dale Kutzera
Re: remove a color cleanly and replace with another
on May 19, 2012 at 6:08:51 pm
I've used the change-color brush in Photoshop with good results.
Tudor "Ted" Jelescu
on May 19, 2012 at 7:04:10 pm
One way would be to use a Color Range Key to key out the color from the image and then use the same footage under the layer with the key to color correct for those areas to the desired color.
Tudor "Ted" Jelescu
Senior VFX Artist
