AE CS6 and Mocha
Eric Kirk
AE CS6 and Mocha
on May 18, 2012 at 12:43:36 pm
Hello,
Does anyone know how to changed the default path for Mocha in AE CS6?
My problem is if I hit "track in mocha" (under Animation tab), it opens up the Mocha for AE version that came with CS6 and not the Mocha for AE V3.0 that I just purchased.
I really don't normally use that feature via animation but I suppose I'd like it to work if I do. :)
Eric
Eric D. Kirk
http://www.kirkproductions.com
Roland R. Kahlenberg
Re: AE CS6 and Mocha
on May 18, 2012 at 3:06:28 pm
Good question Erik. I think mochaImport+ helps with this. Unfortunately, I haven't tested mocha V3.0 via the menu item or with mochaImport+. You should visit the Imagineer Systems site forum with your Q if you need a quick answer.
Cheers
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Eric Kirk
on May 18, 2012 at 7:26:27 pm
Thanks.
I do use Mocha Import+ so I suppose I don't really need it then.
Eric
Eric D. Kirk
on May 18, 2012 at 7:34:29 pm
Hi Erik, just to be clear, I've not tested mochaImport+ nor CS6's menu item that activates mochaAE. I do however have mochaPro V3 and mochaImport+. Do let us know should you find a solution to activate mocha V3 using AE's menu item/command.
TIA
RoRK
Eric Kirk
on May 18, 2012 at 7:42:59 pm
Oh, it's no problem. I've tested Mathias's MochaImport+ and I know he already prepped it for CS6.
THanks,
Eric
Eric D. Kirk
