Command M no longer adds to Render Queue
David Cabestany
on May 16, 2012 at 7:03:28 pm
I recently upgraded from CS5 to CS5.5 and just discovered that hitting Command M minimizes the window instead of adding the composition to the Render Queue, does anyone know how to remap the keys to that instead?
Thanks in advance.
Brian Charles
Re: Command M no longer adds to Render Queue
on May 16, 2012 at 7:20:49 pm
You must be working on a laptop. Try Command + Control + M.
Or you can use this script to remap keys:
http://www.adobe.com/cfusion/exchange/index.cfm?event=extensionDetail&loc=e...
David Cabestany
on May 16, 2012 at 7:31:21 pm
Nope, I had Use system shortcuts enabled, Todd Kopriva posted the solution in an Adobe forum a few minutes ago.
Thank you very much for taking the time, though, I really appreciate it.
John Cuevas
on May 16, 2012 at 11:40:21 pm
Can you post the solution, so if somebody else searches for it they will find it.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
David Cabestany
on May 17, 2012 at 4:33:31 am
Sure, just go into AE's general preferences and deselect Use System Shortcuts.
Once again thanks to Todd Kopriva for this.
Walter Soyka
on May 17, 2012 at 6:15:15 pm
[David Cabestany] "I had Use system shortcuts enabled"
This is a Mac-specific issue. The shortcut you were using, Cmd-M (for Make movie, recently redirected to Add to Render Queue) is the Mac shortcut to minimize a window to the doc. The Replace Footage command is similarly affected, since its default key binding of Cmd-H conflicts with the Mac system shortcut for hiding the application.
In both cases, if "Use system shortcuts" is enabled, adding the Control key to the AE shortcut (Ctrl-Cmd-M for Make Movie and Ctrl-Cmd-H for Replace Footage) will work.
For Make Movie specifically, you could also use the traditional shortcut Cmd-Shift-/ to add to the render queue.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
