Change the Color of Multiple Layers With Change to Color Effect
Dorian Heller
on May 10, 2012 at 8:22:56 pm
Hello,
I am trying to change the value of many shape layers based on one adjustment layer which controls the main colors and a hue/saturation/lightness expression.
Here's what I am working with:
Adjustment layer:
Color A on Shape layer A is pick whipped to the "Color Control" Effect called "A Color".
Then I added a "Change to Color" Effect, where I want to make the global changes to all the shape layers values via Hue, Saturation and Lightness. I am assuming that once I have the expression for Hue, I can copy and paste it to Saturation and Lightness.
Right now I have the following expression attached to the Change to Color - Hue.
color = effect("Change Color (Global)")("Hue Transform")
change = .2;
convert = rgbToHsl(color) - [0, 0, 0, change];
hslToRgb(convert);
I really want to use expressions to do this effect and am wondering what I am doing wrong. I get the following error:
After Effects warning: Bad method arguments: argument 1 to rgbToHsl() must be of dimension 4
Expression disabled.
What am I doing wrong?
Thanks in advance.
-Dorian
John Cuevas
Re: Change the Color of Multiple Layers With Change to Color Effect
on May 10, 2012 at 8:49:30 pm
I think you need to add another channel there for the alpha, that's why you are missing a dimension.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Dorian Heller
on May 10, 2012 at 8:50:45 pm
Okay, thanks! How exactly would I do that?
Dorian
Cassius Marques
on May 10, 2012 at 9:06:33 pm
you're assigning to the variable "color" a 1 dimension value... and you're passing that out to "rgbToHsl"
It should be something like
convert = rgbToHsl([color,0,0,0]) - [0, 0, 0, change];
or
convert = rgbToHsl([something,something,something,color]) - [0, 0, 0, change];
I'm not sure what should go what to give the desired effect...
but that's your error there.
Dorian Heller
on May 10, 2012 at 9:09:26 pm
Thanks for the idea, unfortunately I'm still getting an error.
Here it is:
After Effects warning: Bad method arguments: rgbToHsl() needs exactly 1 argument
Dorian
Cassius Marques
on May 10, 2012 at 9:25:59 pm
It is one argument...are you sure you wrote it right?
You have to keep the "(" ")"
Worked here...
Dorian Heller
on May 10, 2012 at 9:34:10 pm
Cassius,
You were right, I did forget the quote marks. But now, I am getting a divide by zero error, (arg)! I have changed the values from 0 to 1 and random numeric values but still to no avail:
color = effect("Change Color (Global)")("Hue Transform");
change = 1;
convert = rgbToHsl("1,.3,.6,color") - [1,.2,.4, change];
hslToRgb(convert);
Thanks for all your help!
Dorian
Cassius Marques
on May 10, 2012 at 9:41:11 pm
I'm sorry if this is confusing...It's kind of hard to give you the correct simple answer when i'm unsure what you're going for...
but you got me wrong... I didn't mean the quote marks...I meant you have to leave your 4 dimensions [1,2,3,4] inside the parentesis...so it is only one argument...
I copy and pasted what I wrote you before...and it returned no errors.
Good luck.
Dorian Heller
on May 10, 2012 at 10:39:52 pm
Hmmm... That is weird I am trying to get the shape layers Hue to be controlled by one central Hue control, based on expressions. I have the following expression:
change = 1;
convert = rgbToHsl("1,2,3,4color") - [.2, 2, 2, change];
hslToRgb(convert);
This one is with quotes, and I get the following error:
After Effects warning: invalid numeric result (divide by zero?)
Then without quotes and just "color":
change = .2;
convert = rgbToHsl(color) - [0, 0, change];
hslToRgb(convert);
error:
Then with just numbers:
change = .2;
convert = rgbToHsl(1,2,3,4) - [0, 0, change];
hslToRgb(convert);
So I do think it needs quotes. But I can't seem to figure it out..
Here is the .aep, maybe you could look at it and tell me what I am doing wrong:
http://dl.dropbox.com/u/17788937/Test%201%20copy.aep
Once again, thanks for all your help, I really appreciate it.
Cheers,
Dorian
