Remove Grain-starting settings for H.264 Compression artifact removal
jim bachalo
on May 8, 2012 at 2:44:07 pm
Hi
Trying my best to use remove H.264 compression artifacts from some DSLR footage.
The clip in question can be viewed here-
https://vimeo.com/41773887
pw-bells
Can someone suggest usable starting settings for Remove Grain that might work?
Or should I forget RG and use Neat Video instead?
Local is the new global
Dan Fredley
Re: Remove Grain-starting settings for H.264 Compression artifact removal
on May 9, 2012 at 5:48:54 am
You could get away with a complete sky replacement. Key out the blue using Keylight and replace it with another blue gradient or sky.
Dan Fredley
