MP4 Export for Safari 5.1.5
Patrick Lawrence
on May 7, 2012 at 10:25:22 pm
Hello all,
I am having an issue exporting from AE to MP4's for Safari 5.1.5 running under OS X Lion. The videos no longer play. As far as I can determine, this is only an issue under Lion. Of course, this is the browser the client uses. I have tried all variations of exporting from AE, direct from QT 7 etc to no avail. It seems like there must be a flag to set somewhere that will work. Any pointers greatly appreciated as I have been pulling my hair out and other sites on the web haven't been any help.
-Patrick
Roland R. Kahlenberg
Re: MP4 Export for Safari 5.1.5
on May 8, 2012 at 3:19:32 pm
Which version of AE? And try using AME instead of AE.
HTH
RoRK
Intensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
Patrick Lawrence
on May 8, 2012 at 5:10:01 pm
I'm still using CS5 - waiting for for CS6.
on May 8, 2012 at 6:54:41 pm
Have you tried using AME instead of AE to export/render your H264? FWIW, choose the H264 format instead of Quicktime>MP4. You can import/add an AEP into AME whereby upon import, you will be allowed to choose a composition to render, all from AME, without having to open AE. The advantage AME has over AE is its -pass VBR encoding.
HTH
RoRK
