Optical flares 3d tracking parenting
Miloš Homola
on May 3, 2012 at 6:23:41 pm
Hey I need to advice, how to correctly parent position of plugin Optical flares with some tracking null object (CameraTracker).
I need to achieve parenting x,y,z position separately and I can see that optical flares has x,y connected so Im stucked here, since I can parent only z position corectly with null object. I need separate x,y position and control it separately.
Any advice?
Miloš Homola
Re: Optical flares 3d tracking parenting
on May 3, 2012 at 7:16:43 pm
never mind I found the way
Eric Mc Guire
on Jun 21, 2012 at 1:43:32 pm
Maybe you could share how you did it? So you can give help the same way you asked for it? :)
Dane Cannon
on Aug 15, 2012 at 8:23:40 pm
Under positioning mode, change the source type to 3d, then it will enable you to access the "position z" parameter.
