Transparent alpha Channel problem going from AE to FCP, I am pulling my hair out.
Jordan Schevene
on Apr 29, 2012 at 7:24:06 pm
Maybe I am a perfectionist and should except good enough. If, however, you can help me with this I would be most grateful.
My AE graphics with transparent backgrounds show up with a slight dark outline when in FCP. I have read all the forums and
Rendar Settings in AE CS4:
Animation
RGB+Alpha
Millions of Colors
Straight (Unmatted)
FCP Settings:
Alpha Type straight
Prores422 timeline 29.97fps
Please someone tell me if there is a solution. I have been reading and reading and reading the forums, and can't get the perfection I am looking for. HELP!!
Jordan Schevené
Boulder Productions
Accelerating innovative business through film
http://www.boulderproductions.com
Tudor "Ted" Jelescu
Re: Transparent alpha Channel problem going from AE to FCP, I am pulling my hair out.
on Apr 29, 2012 at 8:11:33 pm
It looks like it's a premultiplication issue - try rendering premultiplied in AE.
Tudor "Ted" Jelescu
Senior VFX Artist
John Cuevas
on Apr 29, 2012 at 10:11:04 pm
To add to what Ted suggested, if you have glows I would suggest changing the background color of your comp(cntl + K) to a color that's similar to your glow color. Often if I'm rendering text with a glow with a straight alpha as the alpha fades off I pick up black outlines. By changing the background color and using a pre-multiplied alpha as the alpha fades in the glow area it picks up a color similar to your glow rather than black.
Least that how it works on an avid.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
