how to precompose multiple 3D solids at one go?
manojit ghose
on Apr 25, 2012 at 8:34:24 am
hello everyone,
i have a comp with "n" number of 3D solids.
what i want is to nest each of them into their own composition with ["leave all attibutes" to the current composition] option. so i can change the content inside each independently.
any ways/script to do it at one go? (with having to manually nest each of them)
thanks
m.
MG
Tudor "Ted" Jelescu
Re: how to precompose multiple 3D solids at one go?
on Apr 25, 2012 at 8:04:30 pm
You may want to check aescripts for that, but just in case you did not think about this option here it is:
Select 3d solid layer Alt click and drag over the footage or image you want to replace the 3d layer with- no need for a precomp. In case you really need a precomp, you can create a Master Precomp, the size of your 3d solid, duplicate that every time you want to replace a solid and apply the above mentioned Alt click and drag over.
Tudor "Ted" Jelescu
Senior VFX Artist
manojit ghose
on Apr 25, 2012 at 8:48:32 pm
hi ted,
i tried aescripts but unfortunately no luck yet! or maybe i didnt look well enough.
i am already using the method you mentioned. however since the source videos are of all different size, i have to manually scale most of them to match the original solid's size (which is basically a grid of solids). but i guess i will have to live with that.
but thanks for the reply :)
MG
