Simulation of long-term exposure light drawing effect?
Caspar Stracke
on Apr 23, 2012 at 1:59:28 pm
Dear high court of AFX magicians (who so brilliantly have guided me in tricky moments in the past years!)
I have another case where I am stuck, hopping somebody has a suggestion:
I need to create the equivalent of a long term exposure "light drawings.".
My subject is drawing with a flash light in my video and I would like to keep a nice solid line of what he was drawing. Tried layering an echoed image, but the light path doesn't add up to a solid line plus all other elements get too overexposed when choosing the appropriate layer behavior.
Any clue? Any plug-in suggestion or any other trick up your sleeves??
With deep appreciation for any hint, greateful as always,
Caspar
Dave LaRonde
Re: Simulation of long-term exposure light drawing effect?
on Apr 23, 2012 at 3:14:25 pm
That look was all the rage a few years ago when Apple was airing an iPod spot in which a listener would wave an iPod around, creating a colored line that would follow the device.
There is at least one AE tutorial here on the COW about it; i bet using iPod as a search term will bring it right up. Perhaps even more than one. You can also check videocopilot; Andrew Kramer's done one as well.
Rest assured, something will turn up.
Dave LaRonde
Sr. Promotion Producer
Dave LaRonde
on Apr 23, 2012 at 7:00:55 pm
Found a link:
http://www.videocopilot.net/tutorials/q/ipod/
Andrew uses Trapcode Particular to do it, but you might be able to substitute CC Particle World if you don't have Particular.
Dave LaRonde
Caspar Stracke
on Apr 26, 2012 at 3:48:47 pm
Much thanks Dave!!
cheers,
Caspar
