Is there a way to "invert" SHIFT-SNAPPING in AE?
Tim Kocher
on Apr 21, 2012 at 12:13:26 am
I was just wondering if it were possible to have the SHIFT-SNAP functionality in AE work in the opposite manner? That is, I would like it so it ALWAYS SNAPS, but does NOT snap when holding down SHIFT. I have an NLE I use that works in the opposite way (SNAPS by default, but holding down shift and it does not snap) and my muscle memory gets massively confused, which naturally leads to errors and frustration.
I can invert it in my NLE, but only partially ... I can turn off snapping and then SHIFT will cause it to SNAP, but only when timeline scrubing and not for other things unfortunately. :(
Thanks for insight, input, adive anyone can offer.
MAIN SYSTEM (NEW!): Asus P8Z68 DELUXE, Core i-7 2600k @ 4.6Mhz (stable), 16gb DDR3 1600 (1833 oc) Vengence RAM, 256gb SSD (OS and Apps Only), 2TB RAID0 Caviar Black SATA3, Nvidia Quadro FX 3700, Windows 7 PRO 64-bit, AE CS5.5PP, all in a customized HAF-X case ... complete with holographic logo. [Air cooled into the low teens idle, 49c under heavy sustained oc'd load.] Dual 19" displays.
© 2018 All Rights Reserved
