Strange duIK Behavior
Gabriel Bucataru
on Apr 20, 2012 at 1:27:15 am
Hi All -
Not sure what I am doing wrong, but just following FAMOS's tutorial using duIK on puppet tool, and for some reason when I add a bone to correspond to a certain puppet tool pin, the bone location is offset at the upper left corner of my precomp as if there's no relative to the layer measurement.
I imported my Illustrator file as a composition with layer size dimensions. Screenshot here:
I am using AE CS5 on a mac with the latest duIK.any clues what I might be doing wrong?
thanks a lot,
gabi
Dale Kutzera
Re: Strange duIK Behavior
on Jun 16, 2012 at 12:56:28 am
the same thing happens to me. Did you ever find a solution?
Grim Roper
on Sep 23, 2012 at 2:46:29 pm
Have you seen Stuart Amos' post in this forum?
http://forums.creativecow.net/thread/2/967107#971057
I was having exactly the exact same problem as you, and the answer for me was that you can't manipulate any of the layer's transform properties before pre-composing and/or applying the script.
If you have to manipulate the transform properties, try checking "Move all attributes into new composition" when you pre-compose. It will be a little bit funky to work with big pre-comps for little things like legs, but it seems to allow the script to do it's work.
Gabi Bucataru
on Oct 8, 2012 at 4:00:57 pm
Hi Grim!
Thanks so much for the reply! Sorry for my delay. Yes!! That takes care of the issue! I hope he will take care of this in future releases - it's such a cool script!
cheers,
gabi
