CC Sphere problem as particle shape
Pedro Amaral
on Apr 13, 2012 at 5:09:01 pm
Hi there,
I'm trying to simulate a liquid sphere explosion into a few drops.
So my idea was to create the drop in a layer, and then for the shatter/explosion, by using Particle Playground, CC Particle World, Trapcode Particular or even Trapcode Form, use this "drop" layer as the shape of the particles.
But when I'm applying this "drop" layer as the particle type the result is only a bunch of white squares coming out of the emitter.
I'm almost sure that this problem is due to a specific effect I'm using for the "drop" which is CC Sphere.
Let me do a simple breakdown of my comp:
I have a 100x100px white solid called "drop" that includes:
1. Fractal Noise - for the fractal shapes
2. CC Vector Blur - to create a "liquid look" on the Fractal Noise
3. CC Sphere - to create the shape of the drop
4. Turbulent Displace - to distort the sphere
So, the result is a good looking black and white drop, and what I want to do is insert it as a particle type / shape of an emitter.
Why am I having this white squares and not the drop itself?
Thank you for your attention,
all the best,
Erik Waluska
Re: CC Sphere problem as particle shape
on Apr 13, 2012 at 5:39:10 pm
It sounds like you just need to pre-comp the drop layer and select "move all attributes" and use the pre-comp for the particle texture instead of the layer with the effects applied.
Jeff Hinkle
on Apr 13, 2012 at 5:43:37 pm
Is your "drop" layer in the same comp as your particle emitter? If so, you'll need to either precomp your "drop" layer or render it out and import the resulting file to use as your particle. After Effects won't see the effects you have applied to that layer before using it as a particle. Hence, you're just seeing the white square you started with.
Whichever method you use, be sure to size down the resulting "drop" comp. Particle systems don't like huge particle layers.
Pedro Amaral
on Apr 13, 2012 at 6:10:48 pm
Thank you for your quick replies!
Well yeah I totally forgot do Pre-comp it!
Worked like charm!
Thank you so much for your help guys!
© 2018 All Rights Reserved
