virtual camera
Charles Binn
virtual camera
on Apr 11, 2012 at 8:47:23 am
I created multilayer 2D scenery with Adobe After Effects CS 5.5
Now I want to move a “virtual 2K HD camera” over the 5K scenery to get a moving shot. Is there any way to cut out parts of the picture with an animated frame except the virtual camera?
Thank you
Charles
Benjamin Ausmith
Re: virtual camera
on Apr 11, 2012 at 2:48:11 pm
Precompose it, drop it into a 2K comp, then animate the position.
Benjamin Ausmith
Post-Production Assistant
Monadnock Media, inc.
Tudor "Ted" Jelescu
Re: virtual camera
on Apr 11, 2012 at 7:44:21 pm
Your scene is as big as you built it.
The camera "sees" whatever dimension you make your comp to be (of course the lens you use matters as far as what you get in the frame, but the size of the frame is determined by the size of the comp).
so all you need is to set the comp size at 2k (or HD, not sure I understand what you mean by "2k HD camera").
Tudor "Ted" Jelescu
Senior VFX Artist
