A bird...
Brecht Boelens
A bird...
on Apr 6, 2012 at 11:31:24 pm
Hey,
First of all, I'm quite new to AE, so pls don't kill me if I'm asking obvious things here...
My problem is:
I have filmed a bird with a clear sky behind him, so I could key that bird out. The keying went ok, but what happened is that I filmed the bird from hand (due to lack of better equipment) and he jumps all over the screen, while I need him to stay in the centre of the screen.
How can I make it so that the bird stays at the center of the screen while perfoming it's flight?
Thx in advance!
John Cuevas
Re: A bird...
on Apr 7, 2012 at 12:47:34 am
You need to stabilize the footage and there a number of ways to do that and a lot of resources you might be interested in(doing a google search for (stabilize and after effects will return a lot tutorials):
After Effects Help CS5 version
Stabilize with Warp Stabilizer CS5.5
Warp Stabilizer Tut at AdobeTV
VideoCopilot Tutorial
Finally there you could use mocha, there are many tutorials that might help you. Here's one: Mocha Import
You will need the MochaImport plugin, but you can get a free demo of it.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Brecht Boelens
Re: A bird...
on Apr 7, 2012 at 1:25:30 am
Thanks John!
Will check it out
