Audio sync problem
Mirza Kadić
Audio sync problem
on Apr 4, 2012 at 8:40:54 am
Hello everyone, this is my first writing here.
I am having a problem for days, and cannot finish my project because of it. I will try to cut the long story, short.
My type of project is typographic one, where music track (with vocal) is perfectly aligned with animation. It's perfectly aligned in after effects, though. When I export it, in whatever format, it's out of sync.
Some information:
- Audio file is wav, 44.100khz
- frame rate is 24fps
- No external plugins used in the project
I've tried almost everything, from clearing the cache, cleaning the project, reinstalling drivers, etc.
Any ideas? It would be much, much appriciated if anyone could help! Thank you in advance!
Steve Blacker
Re: Audio sync problem
on Apr 5, 2012 at 2:09:11 pm
What type of audio file are you using? If you are using an MP3 file, don't. After Effects doesn't play nice with MP3 files. Convert it to WAV and you should see those sync problems go away.
http://www.stephenblacker.com
