Focal plane noise issue
michael saul
on Apr 3, 2012 at 6:48:17 pm
Hi all,
I'm experiencing a weird focal plane noise in AE CS4. I'm moving the camera across a jpg file newspaper headline,(high res, perfectly good file)The file is at an angle and the camera is using narrow depth of field to isolate a line of the headline in focus, but as the camera moves over the plane and the focus adjusts, I get weird, noisy grain between focus points. *See attached File. This is for a feature doc, so it will be projected.
No matter what I do to the camera/focus settings, it doesn't go away unless I turn off depth of field.
Any ideas?
Thanks much
Michael
Tudor "Ted" Jelescu
Re: Focal plane noise issue
on Apr 4, 2012 at 9:01:15 am
The attachment did not make it.
You can try to use an adjustment layer with a animated feathered mask and a Camera Blur to replicate the effect without using DOF in the camera.
Tudor "Ted" Jelescu
Senior VFX Artist
michael saul
on Apr 4, 2012 at 5:04:22 pm
I know, I had a hard time getting the image to upload.
Thanks, I'll give that a try!
