Can you link Audio Waveform to another effect?
Olly Lawer
on Mar 24, 2012 at 9:24:49 pm
I am wondering (and just thinking creatively) if you can link Audio Waveform when connected to an audio track to another effect on another layer - say Cell Pattern for instance. I have played around a bit but I cannot see that any of the values change over time although Audio Waveform is animating. I also cannot see that any keyframes have been created.
I was thinking of using expressions to link properties.
Olly Lawer
Jason Brown
Re: Can you link Audio Waveform to another effect?
on Mar 24, 2012 at 10:28:43 pm
Right click on audio and Under keyframe assistant, convert audio to keyframes
Olly Lawer
on Mar 24, 2012 at 10:33:47 pm
Brilliant. Thank you. Creates a null with the keyframes. Perfect.
Is there an easy way to reduce the keyframes without either manually doing it? I want a smoother movement but don't want to lose the 'in time to music' feel.
Olly Lawer
John Cuevas
on Mar 25, 2012 at 1:40:25 am
Choose all the keyframes you would like to reduce, then go to window -> Smoother. Smoothing at a tolerance of 1, should do the trick.
A more robust(but costly) option is Trapcodes Soundkeys. I believe the demo version will allows you to sample 10 seconds of audio, so if your work is less than that, you are all set.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Tero Ahlfors
on Mar 25, 2012 at 10:37:31 am
There's also the Boris FX Beatreactor.
